23802 Discussions
XTU showing incorrect GPU RAM
IBaya
I bought a laptop with GTX1060 DDR 6gb.
I have noticed in XTU that it is only showing 4gb of RAM.
Using dxdiag and gpu-z it shows 6gb.
Which one is correct? Is my GPU defective?
Thanks & Cheers!
Stefan3D
Same here, indeed a bug in XTU
Hello Vixzel,
I understand that you are having issues with our https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- Intel® Extreme Tuning Utility
In this case, please note that our https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- Intel® Extreme Tuning Utility tool can be used by any device but it is specially designed for desktop systems. Since in this case you are using an OEM customized computer with our Intel® Extreme Tuning Utility , we don't really know where the readings (GPU) are coming from, especially because that most of the BIOS setting are coming from the actual system manufacturer and most of the time, it's pre-defined.
The best thing to do at his point will be to check the memory directly from the BIOS since the manufacturer customizes the information displayed in there.
Diego S.
IBaya
Thank you for your reply Diego.
I understand now that XTU is mainly for desktop.
I will just treat this as bug on the XTU interface since
dxdiag, cpu-z and gpu-z are displaying the correct value.
Cheer and regards,
Vixzel
StevenR
I have this same issue and I have this XTU installed on my own build, it's showing my GTX Nvidia 1070 at only 4 Gigs and the integrated Intel graphics at 1.00 Gig, it should be 2 Gigs, my 1070 should be 8 Gigs. Everything else is correct. My MOBO is showing OEM, so this happens on desktops too right?
AlHill
What is your processor model number?
Also, this thread is two years old.
StevenR
Two years old lol.. It's an Intel® Core™ i7-4790K CPU @ 4.00GHz.  Haswell 22nm on a Gigabyte Z87X, Socket 1150 LGA. I googled the incorrect results in google came up with this post. I'm not going to or trying to overclock my CPU, I was more curious about the software, & then I got even more curious as to why I was getting an incorrect reading.
Xero-Hero
It's 6 years later and this bug still hasn't been fixed?  I'm getting the same problem... It's showing my vram as 4gb but I have 8gb
Xero-Hero
6 years later and this bug still has not been fixed.  c'mon Intel, get your act together
