23783 Discussions
a750 csgo2
abc123123
when the flash bombs or the Incendiary bombs exploding,my pc will broke down
Jean_Intel
Hello abc123123
Thank you for posting in the Intel Communities. We would be more than glad to help you with the issue when playing Counter-Strike 2.
To better assist you, we would like to ask for the following information:
  • When did the issue start?
  • When you mentioned that your PC will break, do you mean that you experienced a crashing issue?
  • Was there any other graphics card installed in the system before you installed the Intel Arc graphics?
  • Is Resizable BAR enabled?
  • What steps have you taken to solve this issue?
  • We understand that you have an Intel® Arc™ A770, but we would like to check more details about your card. Is it a Limited Edition card, or is it a graphics card from any of the other manufacturers: Acer, AsRock, Sparkle?
  • To have more information about your system, create a report using the Intel®️ System Support Utility (Intel®️ SSU):
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Best regards
Jean O.
Jean_Intel
Hello abc123123,
We are checking in your thread to see if you have been able to gather the information we requested. Please note that the information will help us to further investigate your issue.
Best regards
Jean O.
Jean_Intel
Hello abc123123,
Since we have not received a response from you, we will proceed to close the thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards
Jean O.
