23787 Discussions
bug report, drivers intel
jgrei1
AlHill
You are using windows 10 1803. That is two years old.
With dual graphics, your need to use BOTH the intel and nvidia drivers from Lenovo.
If you insist on using the latest Intel driver for your 7th gen processor, you can get it here:
https://downloadcenter.intel.com/download/29426?product=95451
However, if you can install it, you will likely lose all customizations Lenovo has made to the driver. More likely, you will be unable to install it.
You should first UPDATE to Windows 10 1909:
https://www.microsoft.com/en-us/software-download/windows10
Doc
jgrei1
I using the 1909 version of windows is same problem i back to 1803 because no problem with the videos, the problem is with the Intel drivers and the old drivers (its works fine) non compatible with the new version of windows and google chrome
AlHill
Let's work with 1909, and use oly the lenovo drivers (intel and nvidia).
And, provide an ssu from 1909.
Doc
jgrei1
I prove happen, trust my word. re-install take time and after back to 1803, take time again.
AlHill
Ok, then use both the Intel graphics driver and the nvidia graphics driver provided by Lenovo. If you still have problems, contact lenovo for support of their laptop.
Doc
jgrei1
I fist I did and they say me contact to intel because is a original driver problem, I like to talk with intel support and not a member forum.
AlHill
Lenovo supposedly tested those drivers on your laptop. It is their problem.
And, I am curious about your going from 1803 to 1909, and then back to 1803. If you took the trouble to get current with 1909, why go through more trouble to go back?
Also, you should spend some time searching for youtube and chrome issues.
Doc
jgrei1
you are a nasty person Mr. AL.Hill
AlHill
Not really. There are rules, and you did not follow them, or were unaware of them. Whatever the case, consult with your laptop manufacturer. And, why would you not want to be on 1909?
Doc
jgrei1
please do not answer more this post does not contribute to the solution
AlHill
You have not tried my suggestions, nor did you provide what I asked for. And, what you do not understand is that with dual graphics you should use only the drivers provided by Lenovo because they have been modified for your hardware..
You want help, let's start with 1909 and go from there. There have been many changes to W10 since 1803 that could have corrected your problem.
Doc
AndrewG_Intel
Hello jgrei1
Thank you for posting on this Intel Community.
We would like to inform you that we are checking the behavior you described and testing it in our lab. As soon as we have more details available we will be posting back in this thread.
Andrew G.
jgrei1
AndrewG_Intel
Hello jgrei1
Thank you for your patience in this matter.
We would like to inform you that we have tested the behavior you described and it was debugged and found to be an issue with the operating system. In this case, what we recommend is reporting this to Microsoft® Support.
Andrew G.
Note: Once you work with Microsoft® support, you can provide feedback regarding what they say. You may provide the support-thread link or MS ticket#.
