22946 Discussions
can someone help me set a custom resolution to 1920x540
head2
this is my system info
Operating System: Microsoft Windows 10 Home(10.0.18363 Build 18363)
Physical Memory (Installed): 8 GB
Processor: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
System Type: x64-based PC
Total Installed Updates: 27 Updates - See Detailed View for more information
Display Adapter(s): Intel(R) UHD Graphics 630 26.20.100.6911
NVIDIA GeForce GTX 1650 27.21.14.5167
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: G531GT
Network Adapter(s): Bluetooth Device (Personal Area Network) 10.0.18362.1
Intel(R) Wireless-AC 9560 160MHz 21.80.0.4
Realtek PCIe GbE Family Controller 10.31.828.2018
Disk(s): Lexar USB Flash Drive USB Device 14.57 GB (available) 10.0.18362.1
Micron_2200V_MTFDHBA512TCK 361.86 GB (available) 10.0.18362.1
im trying to make a custom resolution 1920x540 with intel graphics command center but whenever i try to make the resolution it gives me an error message saying couldnt add the custom resolution reason bad parameters, is there a way for me to make a custom resolution of 1920x540
Sebastian_M_Intel
Hello head2,
Thank you for posting on the Intel® communities.
As per the information you shared here and in the previous thread, please check the following information:
1. Intel® Graphics Command Center does not support resolutions lower than 800x600, as per Windows* 10 requirements.
2. Custom resolutions are considered overclocking, and this might damage your components.
3. Also, for these custom resolutions, your display should support that, most likely; advanced Custom resolutions are not supported for Built-In Displays, as per the manufacturer's design. You can double-check with Asus* for the supported resolutions in this system.
Note: Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Sebastian M.
Intel Customer Support Technician.
Sebastian_M_Intel
Hello head2,
I hope the previous information was useful.
As we advised previously, the Intel® Graphics Command Center does not support resolutions lower than 800x600, as per Windows* 10 requirements. You might also want to check with the manufacturer to see the supported resolutions.
I will proceed to close this case, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sebastian M.
Sebastian_M_Intel
Hello head2,
I will proceed to close this inquiry, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sebastian M.
