23719 Discussions
can't launch app
nguym
 I downloaded this game Valorant and opened Intel graphic command center to adjust some settings. Then I hit launch to open the app but it said "the executable for the program could not be found". Can you help me with this?
AlHill
Explain yourself better and provide some information.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
nguym
Sorry for not being clear. I downloaded this game Valorant and opened Intel graphic command center to adjust some settings. Then I hit launch to open the app but it said "the executable for the program could not be found". Can you help me with this?
AndrewG_Intel
Hello @nguym
We are checking this thread and we found another thread describing the same issue and the same hardware/software environment as this one. Therefore, we will close this thread to avoid duplication of effort,
We will continue working on this other thread: "can't launch app".
Andrew G.
