20634 Discussions
can't run 4k movies
vedu
hello i can't run a 4k movie according to my specification 4k shouldn't be a problem
my specifications
intel core I5 4210U
intel HD 4400
4gb ram
1TB HDD
please respond
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
vedu
this is it
Esteban_D_Intel
Hello vedu,
I would like to share with you the maximum supported resolutions for your processor:
https://ark.intel.com/content/www/us/en/ark/products/81016/intel-core-i5-4210u-processor-3m-cache-up-to-2-70-ghz.html
As you can see in the technical specifications for your processor the Max Resolution that the processor will support via HDMI 1.4 is 3280x2000@60Hz.
It’s worth mentioning that the system or device display resolution is dependent on multiple system design factors including output ports in the laptop, the use of a high-speed HDMI cable, and a display that supports a 4k resolution.
I would recommend checking with your laptop manufacturer for the maximum supported resolutions for your device.
Esteban D.
vedu
well i can easily watch 4k videos on youtube but when i download them they starts lagging very much and video becomes unwatchable
Alberto_Sykes
vedu, Thank you very much for providing that information.
Did you check about this matter with your laptop manufacturer?
Albert R.
A Contingent Worker at Intel
vedu
i am waiting for their reply i will tell when they do
vedu
i don't know why but they are not replying me
Alberto_Sykes
vedu, Thank you very much for providing those updates.
At this point, we will need to wait for the response. So, do not worry, the thread will remain open until they provide their response.
Albert R.
Alberto_Sykes
vedu, I just wanted to check if by any chance you already received a response from HP and if you need further assistance on this matter?
Albert R.
Esteban_D_Intel
Hello vedu,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
