22722 Discussions
code 43
Reanles
After installing the latest driver, version 101.8132, the computer didn't display anything at first. I deleted it with DDU and reinstalled it, but it took about an hour for the screen to appear. Even after the screen appeared, no matter what I tried, I kept getting this error. What nonsense is this?
JeanetteC_Intel
Hello Reanles,
Thank you for posting in Intel Communities
I would like to know more about your system details to fully understand where the issue truly lies. Please provide the missing key information below:
1) Is this an out of the box issue for your Intel® Arc™ A750 Graphics, or has it worked before it failed?
2) If previously worked, what changes has been made prior to the issue?
3) Please let me know which previous driver version works best for your system before you updated to version 101.8132.
4) How are your display/monitors connected to the PC?
5) Share your monitor/display details:
  • Make and model and specifications link.
  • Which ports and what cables were used?
  • Are you using direct cable (e.g. HDMI-to-HDMI, etc.), using a converter/adapter or a docking station?
6) Share your PSU details.
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
I hope to hear from you soon.
JeanetteC.
Reanles
No, I haven't encountered this issue at all since I got the card, even when using the old driver. I currently have version 7029 installed and there are no issues. The PSU is sufficient. It's related to the driver and I'm connected via DisplayPort. The lack of image on the screen is directly related to the card not working on the PC after driver installation, so it's not related to my card or the screen. And the PSU is 600W.
JeanetteC_Intel
Hello Reanles,
I appreciate this clarification. However, to conduct a thorough analysis and provide you with the most accurate solution, I still need you to generate and share the SSU log file as previously requested. This system configuration data will help me:
  • Verify your current driver and system setup
  • Identify any potential conflicts or compatibility issues
  • Determine the most appropriate troubleshooting steps for your specific configuration
Could you please proceed with generating the SSU log file? This will enable me to provide you with targeted assistance for resolving the driver-related display issue you're experiencing.
Thank you for your cooperation.
JeanetteC.
