22671 Discussions
configuracion pantalla
antonyNuñez
Hola quisero saber y como es posible hacer que me salgan la configuración de pantalla en el centro de control intel porque no me aparece por más que desconecte la grafica ni nada por el estilo y seria de mucha ayuda si me dan respuesta esto. 
Adjunto la imagen para mejor referencia..
Jose_Intel
Hello @antonyNuñez
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
We understand you are having some difficulties with the Intel® Graphics Command Center, we will be more than happy to assist you.
We will need more information, please answer the following:
·      Which configuration screen/tab/mode are you looking for?
·      Was it working before?
·      Have you made any recent changes?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Graphics Command Center
Jose B.
Jose_Intel
Hello antonyNuñez
We hope you are doing fine.
Were you able to check the previous questions?
Let us know if you still need assistance by attaching the required reports.
Jose B.
Jose_Intel
Hello antonyNuñez
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
