22988 Discussions
Intel Arc 770 doesnot have 2440p resolution when connected to DP port.
PCGoon
I have an Intel-branded Arc 770 GPU running with 13th Gen Intel i7 with Windows 11. I have two Dell monitors that do support 2560×1440p resolution. The setup was working fine until recently. Recently, there is no more 1560x1440 available on DP port anymore. All three DP ports are only running at 1080p. HDMI is still working at 1560x1440p. There are many complaints about this but I don't see any fixes. I am running the latest drivers. My Dell monitor models are : S2722DGM (27" inch).
Jean_Intel
Hello PCGoon,
Thank you for joining the Intel communities to report your problem. We would be more than happy to help you to finally set the resolution as you had it before.
To better help you, please provide us with the following:
  • You mentioned that this issue started recently. Did it start after a Windows or driver update?
  • Is the issue present if you connect only one monitor?
  • To have more details about your system, provide us with system reports using the following tools:
Intel®️ System Support Utility (Intel®️ SSU)
  • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
Intel® Graphics Command Center:
  • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Best regards
Jean O.
Jean_Intel
Hello PCGoon,
We would like to check on your thread to see if you have been able to gather the information we requested in our previous post. Let us know if you have any other question.
Best regards
Jean O.
Jean_Intel
Hello PCGoon,
We will proceed to close this thread now, as we have not heard from you. If you need further assistance, submit a new thread since this one will no longer be monitored.
Best regards
Jean O.
