22655 Discussions
graphic driver for Atom N2800/Windows 7 settings - bad contrast
Hello, we are developing a robust PC System with following hardware configuration:
-Intel Atom prcessor N2800 (Board Type MIO 2262 from Advantec)
-USB camera
-LVDS display 24bit resolution 800x600@100Hz
-Windows7 emdedded
When we power on our system, the contrast of the display is perfect, but when the when the Intel Graphics Accelerator 8.0.2.0.1086 starts, the contrast becomes bad. For Windows XP there is Intel Embedded Media and Graphics Drivers V1.15 available, where we can do some settings, but the newer version 1.18 which is made for Windows 7 does not support our processor (no Atom N2800, only for E6xx and Z5xx)
-Is there a possiblity to do some settings in the Graphics Accelerator?
-Is there an EMGD version for the processor N2800 and Windows7 emdedded available?
Jose_H_Intel1
Hello Roman, you may try the following drivers:
8.0.4.1.1096: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23473 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23473
8.0.4.0.1091: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22633 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22633
8.0.3.0.1089: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22479 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22479
Please bear in mind that the supported operating system is Windows* 7 32-bit.
http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported operating systems
More information is available here:
http://www.intel.com/support/graphics/intelgma3600/sb/CS-034806.htm Intel® Graphics Media Accelerator 3600 Series — Intel® Graphics Media Accelerator 3600 Series FAQ
Hello Joe,
we tried this Drivers, but the Problem is, that the GMA3600 Driver ignores or misunderstands settings from the bios, so when we install driver, the picture becoms bad. Is there a possibility to influence the driver (Setting file..)? Without GMA3600 we we a good Picture but the Problem is only with 60Hz (Windows Driver)
BR Roman
