i5-2410m的hd3000和gt540m双显卡,win8.1安装好后,安装hd3000显卡驱动就会出现黑屏,有背光,此时外接显示器能显示,笔记本屏幕无显示,请问是不是驱动加载显示器的过程中有问题,对了,主板是hm65
What is the driver version you are currently running on the computer?
See here for information about how to get the driver version: http://www.intel.com/support/graphics/sb/CS-011363.htm Graphics Drivers — Identifying Your Graphics Driver Version
Allan
some days ago ,download from intel.com newest driver ,version is 15.28.24.4229,i has try every version on my computer ,but no one can solve this error.i think driver has wronged select VGA monitor,because i can connect a monitor on VGA port,it can display .please forgive my poor English.
系统自带的驱动显示分辨率不正常,而且没法用独立显卡,必须安装hd3000的驱动,可安了就黑屏,我都无奈了,有说法是bios的问题,可为啥是安装驱动才黑的,驱动也有关系才对。
Yes,it does. I have the same problem in my notebook. After install/update the version 9.17.10.4229(15.28.24.4229), all black only can see the mouse.
Also have a external monitor.
But my os is not Win8.1, it is Win10TP(10130). It looks like it doesn't matter with systems.
