23082 Discussions
how can i change the minimum graphics memory of intel HD graphics 4000
how can i change the minimum graphics memory of intel HD graphics 4000?
my system information is below. 64M minimum graphics memory cant support many games. please help me resolve this problem.Thanks.
My notebook is thinkpad x230. OS: win7 pro 64b
00
Don't worry about the min. Graphic Setting
The HD 4000 automatic use more RAM if needed up to you max. available graphic Memory.
i know this, but many game cant work, such as pes2013, because the game identifies 64M minimum graphic Memory ,and it needs 128M or more to run. I just want to change the value even it does not work at that condition. So, can you help me?
the tool is no longer up-to-date....thank you
Marcos_U_Intel
Hello Rigang,
Intel graphics do not have dedicated memory but utilizes some of the computer's system memory. The amount of memory you can go up to for your 3rd Generation Intel Core Processors with Intel HD Graphics 4000/2500 is 1.7GB, but it all depends if your system manufacturer will let you have the option to change it. Furthermore, you should check with your system manufacturer to check if you can change it.
Visit the following URL for additional Graphics Memory information:
http://www.intel.com/support/graphics/sb/cs-029090.htm http://www.intel.com/support/graphics/sb/cs-029090.htm
Michael
pls help me,
i have bought a new laptop lenovo z580 accompanied with intel HD 4000 first time it was 64 MB dedicated Vram but when i installed a new windows (w8) & pes 2013 i had an issue this time it reads my intel dedicated Vram as 32 MB not 64 MB how can i solve this issue pls ???
Marcos_U_Intel
Hello all,
In order to increase your video memory contact your system manufacturer for instructions of where the option is located at the link below:
http://www.intel.com/support/oems.htm http://www.intel.com/support/oems.htm
SKarb
I agree with Micheal, for example I have an ASUS VivoBook S200E; My system didn't execute PES2013, but I go to POST menu of my notebook (the menu which you can see that with DEL key when you turn on PC) and in the advance menu, you can see 'Graphics Configuration' which you can increase your minimum memory with the parameter in this part.
you can see my graphics properties here after I set up from POST menu:
Of course, in my PC it can be increased up to 512 MB, but I think it's better to don't put pressure on my RAM!
Note: I didn't have any user on intel communities, after that I can't find my answer on the net and find it by myself, I decide to reshare my experience for users whom have this problem.
