23795 Discussions
how do change my power efficiency
nclovs
Before there was a little slider on my powers option in the intel graphic command center now its gone i want my power consumption to be high and efficiently to be low so my pc uses more energy and runs faster but now I don't have the power slider thingy.
What to do? how to fix?
Alberto_R_Intel
nclovs, Thank you for posting in the Intel® Communities Support.
In reference to your inquiry about the "Power Consumption" option not showing in the Intel® Graphics Command Center, for testing purposes, please try to uninstall it:
Uninstall the application via Windows* Settings and re-install the application from the Microsoft* Store.
  1. Open Settings Apps Apps and features.
  2. Locate the Intel® Graphics Command Center application and select Uninstall.
And then reinstall it again following the instructions in the link below:
https://www.intel.com/content/www/us/en/support/articles/000055840/graphics.html
If the issue persists after that, then we will do further research on this matter in order to confirm if the option was actually removed from the Intel® GCC. For us to be able to do that, please provide the following details:
What is the model of the Intel® processor?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
You mention that you used to have the option for "Power Consumption" available before, was that on this same machine or on a different computer?
Did you make any recent hardware/software changes that might cause this problem?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello nclovs, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello nclovs, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
