22883 Discussions
how to add intel graphic properties and intel graphic option to context menu plese help me out when right click it only shows up nvidia control panel
Nihal
hey admin tried lot of times and i followed every stuffs on this page but i get this error ...
THE MODULE igfxpph.dll failed to load. MAKE SURE THE BINARY IS STORED AT THE SPECIFIED PATH OR DEBUG IT TO CHECK FOR PROBLEMS WITH THE BINARY OR DEPENDENT .DLL FILES
THE SPECIFIED MODULE COULD NOT BE FOUND any other method to solve... running 64 bit os
i create these two folders igfxcui and igfxDTCM at context menu handlers but dont know
AlHill
What OS are you using? WIndows 10? What version? 1903?
What is your processor model number?
What model number is your laptop or motherboard?
Doc
Nihal
windows 10 enterprise os build 1903 threshold 18362.295  Intel® Core™ Processor i5-8600  lenovo ideapad 330
Nihal
Manufacturer LENOVO
Model LNVNB161216 (U3E1)
Version Lenovo ideapad 330-15IKB
Chipset Vendor Intel
Chipset Model ID5914
Chipset Revision 08
Southbridge Vendor Intel
Southbridge Model ID9D4E
Southbridge Revision 21
n_scott_pearson
Once you have upgraded to a DCH-based graphics driver package, there will be no support for context menu-based invocation of the graphics configuration tool. Instead, an app is used to accomplish the same activities - but it must be invoked from the Start Menu. Intel made this change at the behest of Microsoft and, as far as I know, has no plans to change back.
Reality bites,
Nihal
windows 10 enterprise os build 1903 threshold 18362.295  Intel® Core™ Processor i5-8600  lenovo ideapad 330 but how to my graphics driver package is dch based i gues it is standard based
n_scott_pearson
If build number (last number in version string) is 6444 or higher, it is DCH-based design.
Nihal
Manufacturer LENOVO
Chipset Revision 08
AlHill
With dual graphics you MUST use the drivers provided by Lenovo.
Doc
Esteban_C_Intel
Hello Nihal,
I would like to know if you need further assistance?
Esteban Ch.
A Contingent Worker at Intel
Nihal
AlHill
You cannot add intel graphic properties to the context menu.
Doc
Esteban_C_Intel
Hello Nihal,
Were you able to check the previous post of Al.Hill? If you need further assistance, please let us know.
Esteban Ch.
Esteban_C_Intel
Hello Nihal,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Esteban Ch.
