- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Andreas-Wolf
Thank you for posting in the community! Based on the System Support Utility (SSU) logs you provided, I see that you are using a B580 GPU, and your monitor’s maximum refresh rate is 120Hz at 1080p. Additionally, you are on the latest driver update.
To better investigate this issue, I have a few follow-up questions:
- What is the exact model of your monitor?
- Is the HDMI cable you’re using from the monitor manufacturer, or is it a third-party cable?
- What HDMI version are you currently using?
- Is your system newly built, or did you only upgrade the GPU?
- Have you used Display Driver Uninstaller (DDU) to remove the previous driver and perform a clean installation?
Additionally, to further analyze the issue, I would like to review your monitor’s EDID data. To retrieve this information:
- Install the Intel Graphics Command Center (Beta) from the Microsoft Store.
- Navigate to Support → System Diagnostic.
- Click "Generate Report" to create a text file containing EDID and other relevant graphics details.
Dhanniel M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Everything ok.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Andreas-Wolf
Thank you for updating me on the resolution of your issue. I'm glad to hear that everything is working fine now. As a result, I will be closing this inquiry. Should you need further assistance in the future, please don't hesitate to submit a new question. Please note that this thread will no longer be monitored.
Dhanniel M.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
