Hi guys/girls,
as you can see from the title of my post I have no DVI output when using Intel HD Graphics Media Accelerator.
My CPU and MB combo is i5 2500K and ASRock Z68 Extreme 4 both at stock speeds, my OS is Vista Home Premium 64-bit.
When I don't use Intel graphics driver I don't have any problems with DVI output - ofc then my highest res is 1024x768 which is as bad as the product of these numbers is small.
I have tried installing both the latest drivers multiple times (8.15.10.2418 - dated 10 June 2011 and 8.15.10.2361 - dated 13 April 2011). So far, so bad.
I can use these drivers if I select analog VGA (D-sub) as my input, and everything works then. However, I want to use my damn DVI.
There was also a similar thread @ /thread/22873?tstart=0 http://communities.intel.com/thread/22873?tstart=0.
Any tips? Any1 else with this problem?
Old driver 8.15.10.2219 solved similar problems for some people. You might try this driver.
