22655 Diskussionen
ig75icd32.dll crashes frequently
Mitarbeiter
10.711Aufrufe
I have a Dell M2800 notebook with integrated Intel graphics driver.
When i open our proprietary software tool IVStudio, it crashes on startup due to an OpenGL error.
This does not happen on other dell computers with Nvidia graphical cards.
Faulting application name: IvStudio.exe, version: 0.0.0.0, time stamp: 0x5710d52a
Faulting module name: ig75icd32.dll, version: 10.18.14.4432, time stamp: 0x5708146b
Exception code: 0xc0000005
Fault offset: 0x0047aa87
Faulting process id: 0x20e8
Faulting application start time: 0x01d304539adca64f
Faulting application path: C:\Program Files (x86)\Barco\Simulation\SimSuite\IvStudio\IvStudio.exe
Faulting module path: C:\Windows\system32\ig75icd32.dll
Report Id: d909bec9-7046-11e7-ba89-80000bd4b7c7
Any ideas how to solve this?
24 Antworten
Mitarbeiter
7.445Aufrufe
Andries_Tacq: Thank you very much for joining the Intel® Graphics communities.
I looked for the specifications of the Dell M2800 notebook, but on Dell's web site it says it is no longer available:
http://www.dell.com/en-us/work/shop/productdetails/precision-m2800-workstation http://www.dell.com/en-us/work/shop/productdetails/precision-m2800-workstation
In order to try to assist you:
Do you know the Intel® graphics controller on it?
Which Windows version are you using?
Any further questions, please let me know.
Alberto R
Mitarbeiter
7.445Aufrufe
hi there Alberto,
OS Name Microsoft Windows 7 Professional
Processor Intel(R) Core(TM) i7-4810MQ CPU @ 2.80GHz, 2801 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Dell Inc. A10, 14/05/2017
First graphic card:
Name Intel(R) HD Graphics 4600
Adapter RAM 1,00 GB (1.073.741.824 bytes)
Installed Drivers igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver Version 10.18.14.4432
Second one :
Name AMD FirePro W4170M (FireGL V)
Adapter RAM (2.147.483.648) bytes
Installed Drivers aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver Version 15.200.1065.0
Do you need anything else?
Stefan3D
Geehrter Beitragender II
7.445Aufrufe
Can't you create a high performance profile for ivstudio.exe so that it always uses FirePro as described at https://community.amd.com/docs/DOC-1581 How to Configure Laptop Switchable Graphics | Community ?
Mitarbeiter
7.445Aufrufe
Thank you to Stefan3D for sharing that information.
Andries_Tacq: Thank you very much for providing those details.
If after trying the steps on that link problem remains and since the processor is working with Intel® HD Graphics 4600, we can try to install the following graphics, it is version 4703 the latest:
https://downloadcenter.intel.com/download/26984/Graphics-Intel-Graphics-Driver-for-Windows-15-40-?product=81496 https://downloadcenter.intel.com/download/26984/Graphics-Intel-Graphics-Driver-for-Windows-15-40-?product=81496
Alberto R
Mitarbeiter
7.445Aufrufe
Andries_Tacq: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R
Mitarbeiter
7.445Aufrufe
Hi Alberto
I tried your link above, but i get the error : this operating system is not supported
regards
Andries
Stefan3D
7.445Aufrufe
Andries_Tacq schrieb:
Hi Alberto
regards
Andries
Did you accidentially download the 32-bit version?
If not, install the suggested driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
Mitarbeiter
7.445Aufrufe
Hi Stefan3D,
Thanks for your reply,
I tried all drivers, so the 32 bit and 64 bit, both unsucessful.
When I try the link like for the surface, i can get to the point where i can select the model.
My model Intel HD Graphic 4600 is not listed.
When i select Intel HD Graphic i get the message : it's not recommended,
Do you think i should proceed, as it's not exacly the model of my graphical card which is mentioned.
Stefan3D
7.445Aufrufe
Hi Stefan3D,
The GPU is listed at the link that Alberto suggested
To be on the safe side, create a system restore point before installation (of any software)
https://support.microsoft.com/en-us/help/4027538/windows-create-a-system-restore-point https://support.microsoft.com/en-us/help/4027538/windows-create-a-system-restore-point
Mitarbeiter
7.445Aufrufe
Hi Stefan,
Thanks for you prompt reply
I tried but I am running into the following error :
The driver selected for this device does not support this version of Windows.
Although win7/64 bit in mentioned in the list.
Any idea's?
Stefan3D
7.445Aufrufe
Hi Stefan,
Any idea's?
Stefan3D
7.445Aufrufe
Hi Stefan,
Any idea's?
Sorry, after taking a closer look it appears that the aforementioned driver supports HD 4600 only under Windows 10.
You would have to modify IGDLH64.INF and disable driver signatures at your own risk.
Mitarbeiter
7.445Aufrufe
ok,
thank again for your support.
I will ask our IT department if a windows 10 upgrade is a possibility.
It's maybe better to go for the new drivers on a new OS instead of trying to stick to the win 7 solution.
Mitarbeiter
7.445Aufrufe
Andries_Tacq: You are very welcome. Thank you very much for letting us know that information. Yes, at this point that will be a good thing to do in order to try to fix this problem.
Thank you also to Stefan3D for the suggestions posted previously.
Alberto R
Stefan3D
7.445Aufrufe
ok,
Really looks like the way to go. Found this info at https://security-center.intel.com/advisory.aspx?intelid=INTEL-SA-00077&languageid=en-fr Intel® Product Security Center
15.36 (HSW systems using Windows 7, 8.1)
This Branch has reached end of maintenance
HSW systems can upgrade to Windows 10 and use the 15.40 Code Branch.
Mitarbeiter
7.445Aufrufe
I am expierincing a weird error lately.
It's software relates, but i have no idea where to look for the anwser
My 3D tool does this :
Any ideas?
Mitarbeiter
7.445Aufrufe
Andries_Tacq: In that case we will start a research on this matter. In order for us to be able to do that for you, please provide the information requested on the link below:
/thread/77761 https://communities.intel.com/thread/77761
Alberto R
Mitarbeiter
7.445Aufrufe
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
as shown above the issue is there every time i start the program
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Dell M2800
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Switchable:
AMD FirePro W4170 (FireGL V)
Intel(R) HD Graphics 450
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
internal laptop screen 1920x1080
How much memory [RAM] in the system (see note2 below).
16 Gb
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
no additional hardware needed
Hardware Stepping (see note1 below).
see attachment
Software (SW)
Operating System version (see note2 below).
<td style="border-width: medium 1pt 1pt m...
Mitarbeiter
7.445Aufrufe
Andries_Tacq: Thank you very much for providing that information. Could you please provide the DxDiag file as well? You can see the details about how to retrieve that information on the link above.
Alberto R
Mitarbeiter
7.249Aufrufe
Hi Alberto,
I have added the dxDialog in the post above,
please not that I am now at work and that there are 2 monitors connected, so they will be visisble in the dxdialog and not in the other report, but the problem persisit in both situations
regards
Andries
Antworten
