22952 Discussions
ig9icd32.dll Crashing Application
IPhil1
I had a program (Professional Flight Planner X) running on an old computer with no issues. I just bought this computer last week, and after installing this program on it today, CTD every time on startup. Here's the Windows error log:
Faulting application name: PFPX.exe, version: 1.2.8.0, time stamp: 0x57d8e661
Faulting module name: ig9icd32.dll, version: 22.20.16.4836, time stamp: 0x59e6adf0
Exception code: 0xc0000005
Fault offset: 0x00456d05
Faulting process id: 0x1048
Faulting application start time: 0x01d39bbfb176f2e1
Faulting application path: C:\aerosoft\Professional Flight Planner X\PFPX.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9dc776be3e13ad6d\ig9icd32.dll
Report Id: 8245f88e-31a7-4b09-88ce-43d27f44b1d1
Faulting package full name:
Faulting package-relative application ID:
As you can see, ig9icd32.dll is causing the crash. I'm updated to the latest Intel and Nvidia drivers and there's no change in behavior.
Stefan3D
You can try several things:
1.
Right-click PFPX.exe
select properties
select compatibility and try the options there
2.
Since you have an Optimus rig, you can force to run the game on NVIDIA GPU
Open NVIDIA control panel
3D settings
program settings
add PFPX.exe and force dedicated GPU
3.
Upload a report from https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility for Windows* to find out your particular Intel GPU for which someone can suggest other driver versions
