22685 ディスカッション
igdimdum32.dll crash when running my software
従業員
3,206件の閲覧回数
I currently run a custom piece of software and on the new PC's I am being supplied they have win 10 64bit and the Intel HD 530 graphics driver.
When I run my software I get a software has stop responding message.
Windows event viewer shows the below..
I have the latest drivers .... - (21.20.16.4627)
Can anyone please help...
EVENT VIEWER INFO
Source
Summary
APPCRASH
Date
‎10/‎04/‎2017 13:12
Status
Report sent
Description
Stopped working
Faulting Application Path:
Problem signature
Problem Event Name: APPCRASH
Application Name:
Application Version: 2.2.4.0
Application Timestamp: 58a239ba
Fault Module Name: igdumdim32.dll
Fault Module Version: 21.20.16.4627
Fault Module Timestamp: 58c19fa7
Exception Code: c0000094
Exception Offset: 00087e42
OS Version: 10.0.14393.2.0.0.256.48
Locale ID: 2057
0 件の賞賛
4 返答(返信)
従業員
1,875件の閲覧回数
Hello msaunders,
I understand the file igdimdum32.dll crashes when you open an application.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .xml file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
If possible please provide the name of the custom piece of software you are trying to use.
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred
従業員
1,875件の閲覧回数
Hi Fred,
Thanks for getting back to me.
Here is the file attached.
The software I am using is used on self service machines and runs either a video or displays an image on the home screen I belive this is what is causing the issue as the image will distort as well.
The software will only crash when I try and exit the application.
Look forward to your reply.
Matt
従業員
1,875件の閲覧回数
Hello msaunders,
Thanks for the information you sent to me.
I would like you to try updating some of the computer drivers in a specific order.
Please install this driver, and then restart the computer http://pcsupport.lenovo.com/cr/en/products/DESKTOPS-AND-ALL-IN-ONES/THINKCENTRE-M-SERIES-DESKTOPS/THINKCENTRE-M700/10GT/10GT0059UK/downloads/DS120216 http://pcsupport.lenovo.com/cr/en/products/DESKTOPS-AND-ALL-IN-ONES/THINKCENTRE-M-SERIES-DESKTOPS/THINKCENTRE-M700/10GT/10GT0059UK/downloads/DS120216
Install this other driver, and then restart the computer one more time http://pcsupport.lenovo.com/cr/en/products/DESKTOPS-AND-ALL-IN-ONES/THINKCENTRE-M-SERIES-DESKTOPS/THINKCENTRE-M700/10GT/10GT0059UK/downloads/DS112736 http://pcsupport.lenovo.com/cr/en/products/DESKTOPS-AND-ALL-IN-ONES/THINKCENTRE-M-SERIES-DESKTOPS/THINKCENTRE-M700/10GT/10GT0059UK/downloads/DS112736
Download the graphics that is on this link https://downloadmirror.intel.com/26669/eng/win64_154516.4627.zip https://downloadmirror.intel.com/26669/eng/win64_154516.4627.zip
As soon as the driver has been downloaded on the keyboard press WinLogo key + r, then type in devmgmt.msc, double click on Display Adapters>>Intel HD Graphics>>Driver tab>>Uninstall>>Select the check box Delete the driver software for this device>>OK, restart the computer, and then reinstall the graphics driver with the steps that are on this YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Let me know if issue persists or not.
Fred
従業員
1,875件の閲覧回数
Hello msaunders,
I was wondering if you were able to install the drivers I provided. If you still need assistance just let me know.
Fred
返信
