igfxDH.dll crashes on my machine multiple times per day. Here are a couple of example stack traces:
Faulting application name: igfxEM.exe, version: 6.15.10.4531, time stamp: 0x57ed203b
Faulting module name: igfxDH.dll, version: 6.15.10.4531, time stamp: 0x57ed202d
Exception code: 0xc0000005
Fault offset: 0x00000000000274eb
Faulting process id: 0x15c8
Faulting application start time: 0x01d3eee586f8bf45
Faulting application path: C:\Windows\system32\igfxEM.exe
Faulting module path: C:\Windows\system32\igfxDH.dll
Report Id: 15994482-64ed-495e-93e7-440c8bab01ce
Faulting package full name:
Faulting package-relative application ID:
Faulting application name: Explorer.EXE, version: 10.0.17134.1, time stamp: 0x425b30b2
Faulting module name: igfxDI.dll, version: 6.15.10.4531, time stamp: 0x57ed2005
Fault offset: 0x0000000000011295
Faulting process id: 0x1560
Faulting application start time: 0x01d3ed4d74b259d3
Faulting application path: C:\Windows\Explorer.EXE
Faulting module path: C:\Windows\system32\igfxDI.dll
Report Id: 72a0b937-d7a7-4762-8b85-962d6bbb6031
Hello 407008795831041274155318234330,
Thank you for contacting us.
I understand that you are experiencing issues with your system.
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
I hope this helps.
Diego S.
We just wanted to double check if you still need further assistance.
Please do not hesitate on contacting us back.
Diego S.
