23081 Discussions
intel 515 quantization settings missing - can't change to full rgb
SSuma3
hi, i'm trying to calibrate my graphics tablet (huion kamvas 151hdv2) to match up my laptop monitor (windows 10, intel HD 515, driver ver. 21.20.16.4550) and while the hues match up, i'm encountering washed out colors only on my graphics tablet. after much googling ive discovered that this is an easy fix by going into the graphics control panel and changing the settings from "limited rgb" to "full rgb" but i'm missing any advanced settings or quantization settings ?
not sure what to do next, but i'm losing my mind in frustration... i've tried:
-manually calibrating
-using a colormunki calibrator
-restarting my laptop
-restoring all my default settings
-updating my drivers manually/automatically
-driver rollback (intel515 users have said a previous that fixes this problem but it didn't work for me?)
-disconnecting my graphics tablet and recalibrating each screen separately
everything i paint looks horribly oversaturated on my laptop monitor because it looks washed out when i paint it on the graphics tablet 😞
here's screenshots of my control settings. i've heard some users say that changing from "limited" to "full range" under video settings works, but there's still a noticeable difference between my graphics tablet and my laptop monitor.
Leonardo_C_Intel
Hello SSuma3 Thank you for posting in the Intel Community. • What is you hardware configuration? (Brand and models for both tablet and laptop, if possible what are the parts number for the systems). • What is the operating system on the tablet and graphics drivers? • Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility (complete this report on both systems). • Steps to save the report: 1- Run the utility. 2- Click on “Scan” to get the scanned system. 3- Once the scan is complete click on “next”. 4- Use the “save” option, save the report to your desktop. 5- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello SSuma3 I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
