22663 討論
intel HD3000 doesn't send full range RGB 0-255 trought HDMI
DTucc
初學者
27,515 檢視
As the subject says,
I cant enable full range RGB output trought HDMI. But there is no problem sendig full range signal throught vga or dvi connectors.
It's an old problem that never got fixed.
Please review this problem and provide a fixed driver.
There was an option to choose Full Range or Limited Range in the intel proprties application but got removed or never worked.
This problem, i repeat, exists only with the HDMI output.
Another problem is that intel drivers don't respect EDID Override option in the registry.
http://msdn.microsoft.com/en-us/library/windows/hardware/gg487330.aspx http://msdn.microsoft.com/en-us/library/windows/hardware/gg487330.aspx
0 積分
51 回應
SMich7
初學者
8,347 檢視
Thanks dtuxi,
Think I tried that already - but I didn't see the byte sequence (0xE2, 0x00, 0x0F) anywhere. I'll give it another try - and this time make sure I follow your steps exactly (I might have missed something ).
FYI I trying this using direct connection from the computer to projector (no AVR inbetween as to aviod 'interference').
Again thanks for you help!
DTucc
初學者
8,347 檢視
please paste the content of the .inf here
BBurt2
初學者
8,347 檢視
Hi dtuxi.
I also have this problem on my BenQ EW2420 monitor. Hope you can help edit my .inf file (I don't have 0xE2, 0x00, 0x0F anywhere):
; INF file generated by Monitor Asset Manager (2.70.0.989), 09/07/2013
; Copyright (c) 1995-2013, EnTech Taiwan.
; Internet: http://www.entechtaiwan.com/ http://www.entechtaiwan.com
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=09/07/2013, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\BNQ7923
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\BNQ7923
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x09,0xD1,0x23,0x79,0x45,0x54,0x00,0x00,0x2E,0x14,0x01,0x03,0x80,0x35,0x1E,0x78,0x2E,0x60,0x85,0xA6,0x56,0x4A,0x9C,0x25,0x12,0x50,0x54,0xA5,0x6B,0x80,0x81,0x80,0x81,0x00,0x81,0xC0,0xA9,0xC0,0x81,0x40,0xD1,0xC0,0x61,0xC0,0xB3,0x00,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0x13,0x2B,0x21,0x00,0x00,0x1E,0x00,0x00,0x00,0xFF,0x00,0x48,0x42,0x41,0x30,0x36,0x34,0x34,0x35,0x30,0x32,0x36,0x0A,0x20,0x00,0x00,0x00,0xFD,0x00,0x32,0x4C,0x18,0x53,0x15,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x42,0x65,0x6E,0x51,0x20,0x45,0x57,0x32,0x34,0x32,0x30,0x0A,0x20,0x01,0x1F
;Extension bloc # 1, e.g., CEA-EXT, DID-EXT, etc.
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x23,0xF1,0x4E,0x84,0x02,0x03,0x01,0x06,0x07,0x15,0x16,0x12,0x10,0x1F,0x13,0x14,0x05,0x23,0x09,0x07,0x07,0x83,0x01,0x00,0x00,0x67,0x03,0x0C,0x00,0x10,0x00,0x38,0x2C,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x96,0x00,0x13,0x2B,0x21,0x00,0x00,0x18,0x02,0x3A,0x80,0xD0,0x72,0x38,0x2D,0x40,0x10,0x2C,0x45,0x80,0x13,0x2B,0x21,0x00,0x00,0x1E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0x13,0x2B,0x21,0x00,0x00,0x9E,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x80,0x13,0x2B,0x21,0x00,0x00,0x9E,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0x13,0x2B,0x21,0x00,0x00,0x1E,0x00,0x00,0xCB
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,1
HKR,,PreferredMode,,"1920,1080,60"
[MODE1]
HKR,,MaxResolution,,"1920,1080,60"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\1920,1080,60",Mode1,,"24.0-83.0,50.0-76.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
;YourColorProfileFile.icm for non-sRGB displays
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="BenQ EW2420 (BNQ7923 EDID Override)"
VENDOR="BenQ"
SMich7
初學者
8,347 檢視
Here it comes
; INF file generated by Monitor Asset Manager (2.70.0.989), 06-09-2013
; Internet: http://www.entechtaiwan.com http://www.entechtaiwan.com
[Version]
Class=Monitor
Provider=%MFG%
DriverVer=06-09-2013, 1.0.0.0
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
[Manufacturer]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\JVC9216
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\JVC9216
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x2A,0xC3,0x16,0x92,0x01,0x01,0x01,0x01,0x00,0x12,0x01,0x04,0xA1,0xDD,0x7D,0x78,0x2A,0x6B,0xE9,0xAB,0x54,0x4C,0xAF,0x24,0x0B,0x48,0x4A,0x21,0x08,0x00,0x95,0x00,0x81,0x80,0xB3,0x00,0xD1,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xA2,0xE2,0x84,0x00,0x00,0x9E,0x3F,0x1F,0x00,0x8B,0x51,0x00,0x1C,0x30,0xC8,0x87,0x43,0x00,0x8B,0x1C,0x63,0x00,0x00,0x1C,0x00,0x00,0x00,0xFC,0x00,0x49,0x4C,0x41,0x46,0x50,0x4A,0x20,0x2D,0x2D,0x20,0x58,0x54,0x31,0x00,0x00,0x00,0xFD,0x00,0x17,0x3D,0x0F,0x4B,0x10,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0xAB
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,1
HKR,,PreferredMode,,"1920,1080,30"
[MODE1]
HKR,,MaxResolution,,"1920,1080,30"
HKR,"MODES\1920,1080,30",Mode1,,"15.0-75.0,23.0-61.0,+,+"
[Strings]
MFG="EnTech Taiwan"
PRODUCTID="JVC ILAFPJ -- XT1 (JVC9216 EDID Override)"
VENDOR="JVC"
BBurt2
初學者
8,347 檢視
Thanks, but I'm a little confused. I see references to "JVC". Perhaps you've mistaken my BenQ monitor with MickDK's JVC Projector
DTucc
初學者
8,347 檢視
please paste moninfo Asset Information output
BBurt2
初學者
8,347 檢視
Monitor
Model name............... BenQ EW2420
Manufacturer............. BenQ
Plug and Play ID......... BNQ7923
Serial number............ HBA06445026
Manufacture date......... 2010, ISO week 46
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 530 x 300 mm (24.0 in)
Power management......... Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... TFT
Controller............... Mstar
Firmware revision........ 1.0
Firmware flags........... 0x000000FF
Active power on time..... 10917 hours
Power consumption........ Not supported
Current frequency........ 19.64kHz, 60.00Hz
Color characteristics
Default color space...... sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.649 - Ry 0.338
Green chromaticity....... Gx 0.289 - Gy 0.609
Blue chromaticity........ Bx 0.146 - By 0.070
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 24-83kHz
Vertical scan range...... 50-76Hz
Video bandwidth.......... 210MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1280 x 1024p at 60Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1600 x 900p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
1024 x 576p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing # 1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1089 1095 1125 -hsync -vsync
Detailed timing # 2....... 1920x1080p at 50Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Detailed timing # 3....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing # 4....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing # 5....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
DTucc
初學者
8,347 檢視
MickDK you dont have an HKR,EDID_OVERRIDE,"1" section, make sure you have JVC9216 [Real Time 0x......] selected. this correspond to bytes 80 through FF in Raw Data Windows. if everything is 00 there, i will try to create this block for you, but i cant promise succes.
SoyaBeaner, unluckily your edid doesn´t contain a Video Capability Data Block (it allways start with 0xE2, 0x00, i will try to insert it. but i don know how to do it yet.
I think i was lucky because my EDID contained 0xE2, 0x00..
JSmit57
初學者
8,347 檢視
dtuxi,
Could you please provide full sequence of characters for your VCDB section? As far as I understand 0xE2 0x00 0xCF are only the first three characters of this sequence. It is possible to see highlighted sections of CEA in EDID Manager (http://www.extron.com/download/dltrack.aspx?file=EDID_ManagerV1x0.exe&id=38772 http://www.extron.com/download/dltrack.aspx?file=EDID_ManagerV1x0.exe&id=38772) in bin EDID from MonInfo.
Thanks!
DTucc
初學者
8,347 檢視
look @ page 93 of http://blogimg.chinaunix.net/blog/upfile2/090903185737.pdf http://blogimg.chinaunix.net/blog/upfile2/090903185737.pdf
the first byte of the VCDB is 07h followed by 02h.
07h=111b (only 3 bits)
02h=00010b (5 bits)
so it gives 11100010b=e2h <- first byte
00h <- 2nd byte
and in the 3rd byte the capabilities of the monitor are defined.
The problem is when the Cea Extension block (2nd 128 bits of EDID) does't have e2,00
JSmit57
初學者
8,347 檢視
Thanks!
I used Advanced EDID Editor from Lightware (http://www.lightware.eu/index.php/support/downloads/667-advanced-edid-editor-software http://www.lightware.eu/index.php/support/downloads/667-advanced-edid-editor-software) to add missing Colorimetry block to CEA: it just inserted four characters in 20/7 - 20/10 position (fourth character was 00) and shifted all following character consuming 4 emtpty 00 characters. The checksum was also auto-recalculated.
Then I just replaced first 3 characters of added Colorimetry block with 0xE2 0x00 0xCF and used updated bin to create inf in MonInfo, which showed correct VCDB block in CEA:
CE video capability data
CE scan behavior......... Supports overscan and underscan
IT scan behavior......... Supports overscan and underscan
PT scan behavior......... Not supported
RGB quantization range... Selectable (via AVI YQ)
YCC quantization range... Selectable (via AVI YQ)
Unfortunatelly there appeared no rgb range selection option in Intel Graphics Properties in TV / Monitor Settings even after registry change of SDVOHDMI_SupportCEA861D to 1. It seems that GMA 3600 driver is somewhat different from HD3000 in this matter...
Can you please tell what is the difference in what you've done in the post @03.09.2013 17:25 and @05.09.2013 19:05?
DTucc
初學者
8,347 檢視
MikeDK, try this:
; INF file generated by Monitor Asset Manager (2.70.0.989), 07/09/2013
[Version]
Class=Monitor
Provider=%MFG%
DriverVer=07/09/2013, 1.0.0.0
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
[Manufacturer]
;Base EDID
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x26,0xF1,0x4E,0x84,0x02,0x03,0x01,0x06,0x07,0x15,0x16,0x12,0x10,0x1F,0x13,0x14,0x05,0x23,0x09,0x07,0x07,0x83,0x01,0x00,0x00,0x67,0x03,0x0C,0x00,0x10,0x00,0x38,0x2C,0xE2,0x00,0x4F,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x96,0x00,0x13,0x2B,0x21,0x00,0x00,0x18,0x02,0x3A,0x80,0xD0,0x72,0x38,0x2D,0x40,0x10,0x2C,0x45,0x80,0x13,0x2B,0x21,0x00,0x00,0x1E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0x13,0x2B,0x21,0x00,0x00,0x9E,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x80,0x13,0x2B,0x21,0x00,0x00,0x9E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC3
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,1
[MODE1]
[Strings]
MFG="EnTech Taiwan"
VENDOR="BenQ"
DTucc
初學者
8,347 檢視
Last message was for SoyaBeaner.
Sorry Mike I'm still working on yours.
bivan: I'musing Extron Edid Manager and Moninfo. In Extrons I read the Edid and in Moninfo I make the changes. The two windows side by side .
Keep in mind that you have to change the 3rd byte of the cea extension block like this.
02,03,xx to 02,03,xx+3 because you insert the 3 bytes of e2,00,cf.
This 3rd byte points to the start of the first Detailed Timing Descriptor, In case that inserting the 02,00,cf makes the last Detailed Timing Descriptor go over the end, you have to set the last Detailed Timing Descriptor to all 00, till the cheksum. This Descriptors are sorted in preference order.
DTucc
初學者
8,347 檢視
MickDK,
This is an JVC rs20 , modded for full rgb, taken from here http://www.avsforum.com/t/1227161/edid-overrides-to-solve-bitstreaming-issues-for-ati-5xxxs EDID Overrides to solve bitstreaming issues for ATI 5xxx's
[Version]
Class=Monitor
Provider=%MFG%
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
[Manufacturer]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x2A,0xC3,0x16,0x92,0x01,0x01,0x01,0x01,0x00,0x12,0x01,0x04,0xA1,0xDD,0x7D,0x78,0x2A,0x6B,0xE9,0xAB,0x54,0x4C,0xAF,0x24,0x0B,0x48,0x4A,0x21,0x08,0x00,0x95,0x00,0x81,0x80,0xB3,0x00,0xD1,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xA2,0xE2,0x84,0x00,0x00,0x9E,0x3F,0x1F,0x00,0x8B,0x51,0x00,0x1C,0x30,0xC8,0x87,0x43,0x00,0x8B,0x1C,0x63,0x00,0x00,0x1C,0x00,0x00,0x00,0xFC,0x00,0x49,0x4C,0x41,0x46,0x50,0x4A,0x20,0x2D,0x2D,0x20,0x58,0x54,0x31,0x00,0x00,0x00,0xFD,0x00,0x17,0x3D,0x0F,0x4B,0x10,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0xAA
HKR,EDID_OVERRIDE,"1",0x01,0x02,0x03,0x24,0x34,0x4F,0x85,0x94,0x90,0x9F,0x20,0x04,0x13,0x11,0x12,0x02,0x03,0x15,0x16,0x06,0x07,0x6C,0x03,0x0C,0x00,0x10,0x00,0x38,0x2D,0xC0,0x21,0x21,0x2A,0x2A,0xE2,0x00,0x4F,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xA2,0xE2,0x84,0x00,0x00,0x1E,0x02,0x3A,0x80,0xD0,0x72,0x38,0x2D,0x40,0x10,0x2C,0x45,0x80,0xA2,0xE2,0x84,0x00,0x00,0x1E,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0xA2,0xE2,0x84,0x00,0x00,0x1E,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0xA2,0xE2,0x84,0x00,0x00,0x1E,0x01,0x1D,0x80,0x3E,0x73,0x38,0x2D,0x40,0x7E,0xB8,0x45,0x90,0xA2,0xE2,0x84,0x00,0x00,0x1E,0x00,0x61
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,1
[MODE1]
[Strings]
MFG="EnTech Taiwan"
VENDOR="JVC"
Message was edited by: Daniel Tucci
BBurt2
初學者
8,347 檢視
dtuxi,
I really appreciate your time and help on this. However, I'm lost on your steps 6 & 7:
6) Then go to Device Manager, Display and you should have 2 monitors, identify your projector, (properties, details, hardware id).
7) Then manually update the projector driver with the .inf (update driver, search driver in equipment, choose from a list, have disk, choose install aniway in the not signed driver prompt)
😎 if everithing goes ok, reboot.
9) in intel driver properties change to full range
In Device Manager, I still only have 1 entry under "Display adapters": Intel(R) HD Graphics.
When I attempt to manually update the driver with the new .inf file, I see this error dialogue: "The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for x64-based systems." This is even after I unticked "Show compatible hardware" on the previous screen.
I'm on Windows 7 x64 if that matters.
DTucc
初學者
8,347 檢視
Sorry not Display Adapters, under Monitors
BBurt2
初學者
8,347 檢視
Thanks! I'm not sure if it really worked for, but some things did change:
1) My Quantization Range now keeps reverting to "Default" upon reboot. Intel's help states "Default is range specified by the display" I'm on the original Intel HD Graphics (first gen), so maybe the setting is different. There are 3: Default, Limited, Full. At least it doesn't keep reverting to Limited like it used to.
2) My colours are now washed out (likely related to the ICM color profile being reset). Actually, this is how it looked when I last reformatted Windows 7. Hopefully I can remember how fixed this in the past. I think it was through downloading my monitor's driver via Windows Update, but then that would defeat the purpose of this overrided .inf file .
3) In checking against http://www.lagom.nl/lcd-test/gradient.php# gradient-h.png Gradient (banding) - Lagom LCD test , I still have visible banding (that doesn't appear when I'm using old fashion VGA cable). I guess it didn't work after all.
DTucc
初學者
8,347 檢視
cHECK THIS http://www.lagom.nl/lcd-test/black.php Black level - Lagom LCD test
BBurt2
初學者
8,347 檢視
I've checked that one also. Lagom is the site I always visit to manually calibrate my monitor because I don't have a hardware calibrator. My black levels are actually worst than it was previously, when I was able to view even the top row of squares. I'll have to revert to the monitor's .inf file.
It's strange to conceive the fix requires hacking one's monitor .inf file. If this was the case I wonder how AMD drivers have their own setting to toggle the RGB range...
JSmit57
初學者
8,347 檢視
Advanced EDID Editor changes 1st DTD offset automatically upon inserting new block.
The fact is that I see VCDB with correct values (along with 4 DTDs) in updated bin in MonInfo, but registry override is not effective. Either it is GMA 3600 driver problem or I'm still missing something.
Sbacs
新手
8,313 檢視
Hi dtuxi!
I've followed your guide but I think there is no change. Blacks are greys and a picture is washed out in movies.
The display: Samsung 40A656 TV, the modified driver (inf) is installed.
Graphics driver: 15.33.0 beta (latest whql driver has artifacts whit XBMC)
This driver has Metro UI, I found Limited/Full Output in Video section but nothing changed with this.
The Windows desktop looks OK but with DXVA playback blacks are gone.
What's wrong? (except that drivers have serious problems just like this)
回覆
