23094 Discussions
intel HD4000 (i7-3770) HDMI - no audio playback device at all
DFali
hi all, I have a problem with intel graphics hd4000,
I am using i7-3770 procesor and integrated graphics,
copmuter is connected to LG tv using HDMI, picture is fine, but there is no audio device at all!
can someone help me how to diagnose or investigate why is that? I used intel HD4000 integrated graphics before, and there was an audio device when connected to the very same tv via HDMI, now there is no audio at all:
mainboard is Asrock z77 extreme4
os is win8.1pro 64bit
inted driver is most recent driver as of 23.04.2014
thanks in advance
Kevin_M_Intel
Hi DanielFalin,
Let me help you with the audio playback on your system.
I would like you to do some troubleshooting steps. Please follow these ones:
1. Update the BIOS in your system using the latest one from the Computer Manufacture.
2. Uninstall the current graphics driver. You can check for instructions here:
http://www.intel.com/support/graphics/sb/CS-034574.htm http://www.intel.com/support/graphics/sb/CS-034574.htm
3. Download and install the latest one for your controller at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714
4. Test a different HDMI cable (better Quality).
5. Check the audio options under the Sound options provide by the Operating System and make sure the TV is set as Audio Playback Device.
DFali
Hi Kevin,
1. bios is updated v2.90
2+3. this is the exact driver that I am using, installed and uninstalled few times, tried with older also, from the mainboard manufacturer's site
4. no need to test other cables, i was using this cable yesterday with discreet video card with no issues at all
checked the audio devices:
this is the mysterious part, no audio device at all
Kevin_M_Intel
Thanks for the information.
Can you try installing the Management Engine driver provided by your Computer Manufacture? This will help us when recognizing devices. Let me confirm something else, Are you using any device between the computer and the TV, something like an AVR?
At any time, was it working before?
