23755 Discussions
intel anisotropic filtering not working
kinoa
i have a question is there anyway on how to fix anisotropic filtering not working properly on intel 4000 this problem have been here for a long time apparently lot of people are having the same issue as me and Intel still hasn't fixed this problem with anisotropic filtering here's a screen shot of what i mean.
Allan_J_Intel1
What games are you currently running with issues with anisotropic filtering?
I would like to get graphics report generated within graphics properties.
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics Drivers — Intel® Graphics Driver Report
Also, make sure you are running the latest graphics drivers : https://downloadcenter.intel.com/search?keyword=3rd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4000 Intel® Download Center
Allan.
kinoa
i am currently running minecraft,cs go,and unturned with this anisotropic filtering issues yes i do have the latest driver and here is the report from graphic properties
kinoa
Intel(R) HD Graphics 4000
Report Date: Tuesday, May 26, 2015
Report Time [hh:mm:ss]: 1:20:04 PM
Driver Version: 10.18.10.4176
Operating System: Windows* 8.1 Pro(6.3.9600)
Default Language: English (United States)
Installed DirectX* Version: 11.2
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 3789 MB
Processor: Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
Processor Speed: 1796 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.0
Current Resolution: 1366 x 768
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
Serial Number: LGD039f
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: LVDS
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.78 inches
Vertical Size: 7.48 inches
Supported Modes
1366 x 768 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 9F 03 00 00 00 00
00 16 01 03 80 23 13 78 0A 05 F5 94 58 56 92 28
1E 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 12 1B 56 70 50 00 0E 30 20 20
24 00 59 C2 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 35 36 57 48 33 2D 54 4C 53 31 00 E3
* Other names and brands are the property of their respective owners.
Allan_J_Intel1
Thanks for the graphics report.
At this stage, I need more information about the problem you are experiencing with anisotropic filtering, I would like to know what exactly I need to do to replicate this issue.
What steps have you tried to correct the issue?
Please provide screen shots of your game settings and any other relevant information that will help identify this problem.
Allan.
kinoa
Well I tried to unistall my graphic driver and installed it back again and still it didn't work but this is not a problem with my computer because my friend has the same graphics card as me and has the same problem with anisotropic filtering when he enables it here's a screenshot of my game settings i tried to run the game with anisotropic filtering enable on Intel control panel but as you see those white lines in my screen shot i tried to enable anisotropic filtering on the game but it doesn't have the lines i have mip map and anisotropic filtering is suppose to smooth the mip map details but is not is just making the game have more jaggies here's a screenshot of what i mean and there is a screenshot of my game settings too.
Allan_J_Intel1
I am currently researching on this issue. As soon as I can, I will send you a message with my findings.
Allan.
kinoa
did you find anything about
Allan_J_Intel1
Allan.
kinoa
kinoa
Shader Version: 5.0
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
Video BIOS: 0.0
Active Displays: 1
Gamma: 2.2
Maximum Image Size
Supported Modes
1366 x 768 (60p Hz)
Raw EDID:
Allan_J_Intel1
Allan.
kinoa
Allan_J_Intel1
Allan.
kinoa
MSchm21
Valued Contributor I
This is a known famous Bug from Intel. AF settings from Control panel have no effect since years on directx games even after numerous reports. Some time ago they fixed it on 15.36 driver branch and newer. As far as I know 15.36.3.64.3907 is the first with working control panel AF. Ivy Bridge and older hardware can't use this driver and therefore still suffer from it.
@allan-Intel: you are the best example why Intel didn't bother fixing it for many years. Even Intel workers didn't know it or just didn't bother. I reported this bug here as well several times, so it speaks for itself that you were not aware of it. And Intel didn't bother fixing it for Ivy Bridge.
kinoa
yeah your right because intel af hasn't work since drive V9.17.10.2963.01 because i downgrade to that driver and still didn't work i don't think this is not a issue with my graphics card is a driver issue that intel hasn't fixed.
kinoa
Is there any posibilities intel can fix this bug or something
MSchm21
It never worked fully on any Ivy Bridge driver. Of course they could fix it for Ivy Bridge but since they didn't bother fixing it after they fixed Haswell I doubt Intel will change their mind suddenly.
kinoa
yeah i think your kind of right not even allan_intel try to answer my question or say there's no soluction well i kind of stuck with this graphics card for a long time unless intel fixes this issue on the next driver update which i don't know when it will come out
Allan_J_Intel1
I will post updates to this thread as they become available.
Allan.
