Hi shafay
Where do you get that error message?
Does that happen with a specific application or when you are trying to install/uninstall something?
Thanks!
I Get this message when i try to update the driver I have downloaded multiples files but they all give this error message
my driver is express chipset G41 series
Hi shafay,
Can you attach a copy of your dxdiag please? (Start -> Run -> dxdiag -> Save All Information). Just copy & paste it here and we'll take a look.
-Nic
Thanks for that info shafay. Your BIOS version is dated for 2008, go ahead and upgrade to the following version and let me know if it fixes your issue or not; http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/19952/eng/RQG4110H.86A.0017.EB.EXE&lang=eng&Dwnldid=19952&DownloadType=BIOS&OSFullname=Windows+7+(32-bit)*&ProductID=3058 Download Center
-Nic
What error did you receive while trying to install this update?
-Nic
an error occurred while registering one or more components
this is the error I recieve
I too am still having this same problem.
After having gone through numerous iterations of display drivers (Uninstall, Delete, Reboot, Download, Install).
I still get the same error message:
"an error occurred while registering one or more components"
This is with an Intel 4 Series Express Chipset Family.
If 8.15.10.2869 is the most recent driver, why wont it work?
Also, when doing a manual search for compatible drivers, this driver is listed under:
15.17.19.64.2869
(Latest)
I realize this technology is a little dated, but is there any chance we can get some support from Intel?
Like, ever?
This is starting to make you guys look bad...
Thanks for joining the Graphics community.
I appreciate your feedback on this matter. I will make sure your comment reaches the proper department for future consideration.
Thank you for taking the time to communicate this issue to us.
Allan.
All,
Could you please install the Chipset Software update first, reboot, and then install the 2869 graphics driver? Please report back with your results.
Link to Chipset Software:https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20775&lang=eng&ProdId=816 Intel® Download Center
Robert
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
