22940 Discussions
intel integrated graphics hdmi refresh rate bug
number201724
Recap:
https://community.intel.com/t5/Graphics/The-Intel-integrated-graphics-driver-cannot-find-the-75hz-option/m-p/1441993
I bought 2 nuc12wski7 and NUC12DCMi9, I found that when I use HDMI cable, I can't set 75hz refresh rate.
I use the same monitor, the same cable, plug it into an amd or nvidia graphics card and it can set 75hz correctly.
Whether it is the integrated graphics card of i9-12900 or the integrated graphics card of I7 1260P, the output of 75hz cannot be set under the windows platform.
intel graphics command center can recognize that the display supports 1080p 75hz, but it cannot be set.
But I can display 75hz correctly using ubuntu 22.04 and fedora 37.
Is there any solution please?
Monitor: ASUS PA247CV
Monitor info:
Monitor
Model name............... PA247CV
Manufacturer............. AUS
Plug and Play ID......... AUS2463
Serial number............ MALMQS297132
Manufacture date......... 2021, ISO week 44
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 530 x 300 mm (24.0 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA/CTA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... RealTek 0x2775
Firmware revision........ 0.1
Firmware flags........... 0x00620085
Active power on time..... 2508 hours
Power consumption........ 6.55 kWh
Current frequency........ 67.50kHz, 60.00Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.652 - Ry 0.337
Green chromaticity....... Gx 0.313 - Gy 0.626
Blue chromaticity........ Bx 0.151 - By 0.066
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-83kHz
Vertical scan range...... 24-75Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 864p at 75Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
EIA/CEA/CTA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1920x1080p at 75Hz (16:9)
Modeline............... "1920x1080" 220.750 1920 2056 2264 2608 1080 1083 1088 1130 +hsync +vsync
Detailed timing #2....... 1366x768p at 60Hz (16:9)
Modeline............... "1366x768" 85.500 1366 1436 1579 1792 768 771 774 798 +hsync +vsync
Detailed timing #3....... 1280x768p at 60Hz (16:9)
Modeline............... "1280x768" 79.500 1280 1444 1572 1664 768 771 778 798 -hsync +vsync
Detailed timing #4....... 1360x768p at 60Hz (16:9)
Modeline............... "1360x768" 85.500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Maximum TMDS clock....... 165MHz
CE video capability data
CE scan behavior......... Always underscanned
IT scan behavior......... Always underscanned
PT scan behavior......... Always underscanned
RGB quantization range... Selectable (via AVI YQ)
YCC quantization range... Not supported
IEEE registration number. 0x00001A
CEC physical address..... 0.1.0.1
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 375MHz
Video latency (p)........ 117ms
Audio latency (p)........ 171ms
Video latency (i)........ 255ms
Audio latency (i)........ 351ms
HDMI video capabilities.. Yes
EDID screen size......... Rounded to nearest cm
3D structures supported.. Side-by-side
3D formats supported..... Not supported
Data payload............. 1A00000101304BE6
Report information
Date generated........... 2/15/2023
Software revision........ 2.91.0.1043
Data source.............. Real-time 0xB100 - NB: improperly installed
Operating system......... 10.0.22621.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,06,B3,63,24,01,01,01,01,2C,1F,01,03,80,35,1E,78,EA,15,C5,A7,56,50,A0,26,
11,50,54,BF,EF,00,71,4F,81,80,81,40,81,C0,95,00,B3,00,81,00,A9,40,02,3A,80,18,71,38,2D,40,58,2C,
45,00,0F,28,21,00,00,1E,00,00,00,FD,00,18,4B,1E,53,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,50,
41,32,34,37,43,56,0A,20,20,20,20,20,00,00,00,FF,00,4D,41,4C,4D,51,53,32,39,37,31,33,32,0A,01,2A,
02,03,2C,F1,4D,90,05,04,03,02,01,11,12,13,14,1F,20,21,23,09,07,07,83,01,00,00,65,03,0C,00,10,00,
E2,00,6A,68,1A,00,00,01,01,30,4B,E6,3B,56,80,B0,72,38,32,40,88,D0,35,00,0F,28,21,00,00,1E,66,21,
56,AA,51,00,1E,30,46,8F,33,00,0F,28,21,00,00,1E,0E,1F,00,80,51,00,1E,30,A4,80,37,00,0F,28,21,00,
00,1C,66,21,50,B0,51,00,1B,30,40,70,36,00,0F,28,21,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,B7
number201724
Hello, this is the diagnostic information obtained by using the 31.0.101.1999 version of the driver. DisplayPort can be set to 75hz, but hdmi cannot. In intel's diagnostic information, both monitors can be set to 75hz, and the intel graphics command center shows that the second monitor is 75hz, but it cannot be set. In the settings of windows, one monitor is 75hz (DP), and the other is 60hz (HDMI).
Please note:
Both AMD and NVIDIA graphics cards can be set to 75hz when using the same HDMI cable.
Intel is under the windows system, using DisplayPort can set 75hz, HDMI can not.
The behavior under Linux is consistent with NVIDIA and AMD.
DeividA_Intel
Hello number201724,
Thanks for this information, I will proceed to continue with the investigation and get back to you with further details.
Deivid A.
DeividA_Intel
Hello number201724,
Thanks for your time. In this case, Can you test with the latest generic driver from Intel:
Deivid A.
number201724
Hello, the test results are the same as 31.0.101.1999.
DeividA_Intel
Hello number201724,
Thanks for the confirmation. I will continue with the research to confirm if we have any other way to help you with the situation.
Thanks for your time and comprehension.
Deivid A.
Ronny_G_Intel
Hello number201724,
We were able to use the very same NUC and set the resolution to 1920x1080@75Hz using an HP monitor. We are running the latest graphics drivers and the latest BIOS version. Please refer to the screenshot below.
We don't know the reason why 1920x1080@75Hz is not working for you in Windows* but does work when running Linux*, it may be a compatibility issue between your display and the Windows* driver not being able to detect that the monitor is capable of 75Hz.
We don't really have a solution for this issue as it seems to be very specific to your hardware integration, I would try previous driver versions as the last troubleshooting attempt but cannot guarantee anything.
I apologize for the inconvenience.
Ronny G
number201724
Hello Ronny,
Are you using an HDMI connected monitor?
It can't be set to 75hz only if using HDMI. 😞
I have 2 monitors connected to the same machine, one with HDMI and one with DP.
DeividA_Intel
Hello number201724,
Thanks for the confirmation, seems that the issue persists despite Ronny_G_Intel's information. Allow me to check on this, however, bear in mind what Ronny_G_Intel shared related to this problem.
I will get back to you as soon as possible.
Deivid A.
DeividA_Intel
Hello number201724,
Thanks for your patience. We have tried to replicate with a similar configuration and the resolution of 1920x1080@75Hz worked.
This could be related to the Graphics Driver for Windows that is not recognizing the display as 75Hz capable monitor thus not allowing this refresh rate.
I recommend you get in contact with us directly to discuss the refund options that we have for you:
1. Chat support:  https://intelsupportchat.secure.force.com/icslivechat/ics_tech_processor_ww_english_Chat
2. For phone support, depending on your location, you will see the contact information on the links below:
- EMEA contact information: https://www.intel.com/content/www/us/en/support/topics/support-phone-list.html
- APAC contact information: https://www.intel.com/content/www/us/en/support/topics/support-phone-list.html
- LAR contact information: https://www.intel.la/content/www/xl/es/support/topics/support-phone-list.html
North America: Phone Number 1-916-377-7000, Monday – Friday 7:00 AM to 5:00 PM (Pacific Time).
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
yangdong
1.  ASUS PA247CV monitor' EDID has serious errors, I think you can try to modify the EDID related parameters  use CRU tool: Check Maxmium TMDS Clock in HDMI VSDB。 <20250811-100007.jpg>.
2.  If step 1 does not work, you need to contact ASUS to modify other EDID parameters:
change to "Range Limites 24-75Hz, 30-85kHz, 340Mhz. <20250811-100540.jpg>
3. If step1 and step2 is OK,I think this is ASUS PA247CV issue, not a Intel graphics card issue,although other graphics cards have better compatibility.
