- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
i facing problems with approx. 20 system i5 8th generation brightness option is missing please help us about UHD 630
in windows 11 Pro and also not available in display setting
Link copiato
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello @Asheesh_Chauhan
Was the brightness slider there before?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Intel Graphics Command Center
Please generate both reports from 1 of the affected units.
Jose B.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello Asheesh_Chauhan
We hope you are doing fine.
Please do not forget both reports if you still need assistance.
Jose B.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
