23838 Discussions
nltk error
AShar38
Hi, when I am working on jupyter notebook by login using given credentials, I am getting error while importing nltk as "no module named nltk". I tried to install nltk by entering command "!pip install nltk" in notebook , but getting below error :
Thanks !
Thanks for reaching out to us!
Try these commands from the shell:
conda create -n python=3.6 source activate  conda install ipykernel ipython kernel install --name --user conda install nltk -c intel
Once this is done, launch your python code from hub.colfaxresearch.com
Select Kernel -> Change Kernel ->
Thanks & Regards,
Sandhiya
AShar38
conda tab not showing in my jupyter notebook to change environment.. How can I create and activate environment from shell??
Please try out the previous command from your DevCloud terminal (shell), not in Jupyter notebook.
If the issue still persists, please let us know.
Dona
Hope it has answered your queries. We are closing the discussion since there is no response further. Feel free to start a fresh discussion.
Dona
