- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi @Bandit8623,
Can you please provide the log files from these locations:
C:\Users\<your_username_here>\AppData\Local\Intel\IGN\logs
C:\ProgramData\Intel\GFXInstaller\IntelGfx.log
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
no ign folder
looks like its a dotnet 7 bug
https://github.com/IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT/issues/691
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for the logs!
Can you also please let us know if you had the Intel® Driver & Support Assistant installed when you tried to install the driver?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
yes i do have the driver assistant installed.
its been installed though for quite a few of the driver revisions, cant remember when i added it its been so long 🙂
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Bandit8623,
Thank you for posting in our Intel communities.
We understand that you are having issues with the latest driver, as it does not include the arc control.
In regards to that, kindly provide us with your Intel arc control logs so we may further investigate our issue.
How to Get Log Files for Intel® ArcTM Control Logs:
https://www.intel.com/content/www/us/en/support/articles/000095081/graphics.html
Thank you, and have a great day ahead!
Carmona A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Bandit8623,
We are checking in with you if you already get the log files of the Arc control?
By the way, Please know that we would be happy to assist you if you have any questions.
Thank you, and have a great day!
Carmona A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
well i cant install arc with the driver. so i wont have logs for that. i had to manually install by extracting the installer.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Bandit8623,
Thank you so much for providing us with your arc control logs. We will use it to do further research on the issue that we have and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Carmona A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have never been able to run Intel Arc Control, not even once on my new PC.
Have the Arc750 Limited Edition, have installed every update I've had it (11 months) and Arc Control just doesn't work at all.
Currently have the latest drivers installed...
Checking TaskManager i can see multiple references to Arc control...
If I kill the task off, then re-open Arc Control, on occasion I will get this...
Everything is blank and nothing works.
I've used DDU several times, have reinstalled Win11 Pro from scratch twice in the last 9 months but nothing will work.
Only 1 monitor connected, on-board graphics fully disabled in BIOS
Is it because I'm using an Intel GPU on a AMD-based system?
I can provide logs if requested.
thanks
G
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
