22672 Discussions
non-standard resolution, no signal
Dmitry_M_4
Hello, I'm using latest driver, downloaded by Intel Driver Update Utility for my ASUS UX303LN notebook. I connect to HDMI external stereo-monitor from www.trivisio.com with 2560x1024 resolution (See it's EDID in driver's report in the end of this post). But there is no output from HDMI (checked on HDMI receiver IC). The same hardware successfully works with Ubuntu 15.04. Kind regards Dmitry Intel(R) HD Graphics 4400 Report Date: Tuesday, December 22, 2015 Report Time [hh:mm:ss]: 4:02:10 PM Driver Version: 10.18.10.4252 Operating System: Windows* 10 Pro Insider Preview (10.0.10586) Default Language: Russian (Russia) Installed DirectX* Version: 12.0 Supported DirectX* Version: 11.0 Shader Version: 5.0 OpenGL* Version: 4.2 OpenCL* Version: 1.2 Physical Memory: 3984 MB Processor: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz Processor Speed: 2394 MHz Vendor ID: 8086 Device ID: 0A16 Device Revision: 0B * Processor Graphics Information * Processor Graphics in Use: Intel(R) HD Graphics 4400 Graphics Output Protocol (GOP) Version: 5.0.1036 Current Resolution: 1920 x 1080 * Devices connected to the Graphics Accelerator * Active Displays: 2 * Built-in Display * Display Type: Digital Serial Number: CMN1361 DDC2 Protocol: Supported Gamma: 2,2 Connector Type: Embedded DisplayPort Device Type: Built-in Display Maximum Image Size Horizontal Size: 11,42 inches Vertical Size: 6,69 inches Supported Modes 1920 x 1080 (60p Гц) 1920 x 1080 (40p Гц) Raw EDID: 00 FF FF FF FF FF FF 00 0D AE 61 13 00 00 00 00 07 18 01 04 A5 1D 11 78 02 CE 85 A3 57 4E 9D 26 12 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 36 36 80 A0 70 38 20 40 2E 1E 24 00 25 A5 10 00 00 18 24 24 80 A0 70 38 20 40 2E 1E 24 00 25 A5 10 00 00 18 00 00 00 FE 00 43 4D 4E 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE 00 4E 31 33 33 48 53 45 2D 45 41 33 0A 20 00 A1 * Digital Television * Display Type: Digital Serial Number: TRV0017 DDC2 Protocol: Supported Gamma: 2,2 Connector Type: HDMI Device Type: Digital Television Maximum Image Size Horizontal Size: 50,39 inches Vertical Size: 40,16 inches Supported Modes 640 x 480 (60p Гц) 1280 x 1024 (60p Гц) 1280 x 720 (60p Гц) 2560 x 1024 (60p Гц) Power Management Support Standby Mode: Supported Suspend Mode: Supported Active Off Mode: Supported Raw EDID: 00 FF FF FF FF FF FF 00 52 56 17 00 03 00 00 00 28 19 01 03 80 80 66 78 FF EE 95 A3 54 4C 99 26 0F 50 54 20 00 00 81 80 01 00 01 00 01 00 01 01 01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70 13 00 80 66 00 00 00 1E 00 00 00 FC 00 48 4D 44 34 32 5F 4D 41 49 4E 0A 20 20 00 00 00 FD 00 31 7A 1E 64 11 00 00 00 00 00 00 00 00 00 00 00 FE 00 4D 44 50 30 32 0A 20 20 20 20 20 20 20 01 EA 02 03 17 00 70 03 0C 00 10 00 00 21 20 A0 06 01 41 08 10 00 06 41 04 FC 3F 00 28 A0 00 1A 40 05 05 C2 00 80 66 00 00 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9C
