I'm using latest driver, downloaded by Intel Driver Update Utility for my ASUS UX303LN notebook.
I connect to HDMI external stereo-monitor from www.trivisio.com with 2560x1024 resolution (See it's EDID in driver's report in the end of this post).
But there is no output from HDMI (checked on HDMI receiver IC). The same hardware successfully works with Ubuntu 15.04.
Kind regards
Dmitry
Intel(R) HD Graphics 4400
Report Date: Tuesday, December 22, 2015
Report Time [hh:mm:ss]: 4:02:10 PM
Driver Version: 10.18.10.4252
Operating System: Windows* 10 Pro Insider Preview (10.0.10586)
Default Language: Russian (Russia)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 3984 MB
Processor: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0A16
Device Revision: 0B
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4400
Graphics Output Protocol (GOP) Version: 5.0.1036
Current Resolution: 1920 x 1080
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Built-in Display *
Display Type: Digital
Serial Number: CMN1361
DDC2 Protocol: Supported
Gamma: 2,2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 11,42 inches
Vertical Size: 6,69 inches
Supported Modes
1920 x 1080 (60p Гц)
1920 x 1080 (40p Гц)
Raw EDID:
00 FF FF FF FF FF FF 00 0D AE 61 13 00 00 00 00
07 18 01 04 A5 1D 11 78 02 CE 85 A3 57 4E 9D 26
12 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 36 36 80 A0 70 38 20 40 2E 1E
24 00 25 A5 10 00 00 18 24 24 80 A0 70 38 20 40
2E 1E 24 00 25 A5 10 00 00 18 00 00 00 FE 00 43
4D 4E 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 4E 31 33 33 48 53 45 2D 45 41 33 0A 20 00 A1
* Digital Television *
Serial Number: TRV0017
Gamma: 2,2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 50,39 inches
Vertical Size: 40,16 inches
Supported Modes
640 x 480 (60p Гц)
1280 x 1024 (60p Гц)
1280 x 720 (60p Гц)
2560 x 1024 (60p Гц)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 52 56 17 00 03 00 00 00
28 19 01 03 80 80 66 78 FF EE 95 A3 54 4C 99 26
0F 50 54 20 00 00 81 80 01 00 01 00 01 00 01 01
01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70
13 00 80 66 00 00 00 1E 00 00 00 FC 00 48 4D 44
34 32 5F 4D 41 49 4E 0A 20 20 00 00 00 FD 00 31
7A 1E 64 11 00 00 00 00 00 00 00 00 00 00 00 FE
00 4D 44 50 30 32 0A 20 20 20 20 20 20 20 01 EA
02 03 17 00 70 03 0C 00 10 00 00 21 20 A0 06 01
41 08 10 00 06 41 04 FC 3F 00 28 A0 00 1A 40 05
05 C2 00 80 66 00 00 00 1E 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9C
