22643 Discussions
pourquoi Intel s'ouvre toujours au démarrage
Kriss2440
Intel s'ouvre à chaque démarrage, es-ce normal ?
JedG_Intel
Hello Kriss2440,
Please be informed that I can only support you in English. I have used a web translation tool to translate this response hence, there may be some inaccurate translation.
I did not quite understand what your concern is and for me to address this correctly, please describe the issue more to us.
I hope to hear from you soon!
Jed G.
Kriss2440
Bonjour,
Lorsque je démarre mon PC intel s'ouvre toujours , faut-il autoriser à chaque fois son analyse ?
Merci,
Cordialement
JedG_Intel
Hello Kriss2440,
When you mention that Intel is always open, are you referring to Intel Driver & Support Assistant? If so, you can enable it to ensure you receive the latest driver updates. However, if you prefer not to see this prompt each time you start your PC, you can disable it by accessing the Service Manager. From there, you can turn off the service and change its setting from Automatic to Manual.
Should you have other questions or concerns, please let me know.
Jed G.
JedG_Intel
Hi Kriss2440,
I'm following up to see if you were able to see the information I posted. Please let me know at your earliest convenience so we can determine the best course of action to resolve this matter.
Jed G.
JedG_Intel
Hello Kriss2440,
Jed G.
