22902 Discussions
problem with HDMI and Intel HD Graphics 4000
After installing the latest drivers from Intel HD Graphics 4000 is no longer output the picture on TV connected via HDMI. When removing intel driver and install a standard driver windows 7 TV through HDMI works in clone mode desktop. If start the installation of the latest drivers from Intel after installation and before rebooting the PC it works perfectly - there is an image on the TV, it can be configured as a clone mode and the extended desktop mode, but after rebooting the image on the TV disappears. How to make the TV displays the image after restart the PC with the latest drivers Intel HD Graphics 4000?
CPU - core i5 3570K
MotherBoard - Gigabyte Z77-DS3H
Win 7 64bit
No discrete graphics card
TV - Philips 32PFL8404H
Message was edited by: Timur&# 13; version of solutions: http://communities.intel.com/message/169251# 169251 http://communities.intel.com/message/169251# 169251
NICHOLAS_F_Intel
Realistically, without being able to personally reproduce the issues ourselves, the only thing we could do was speculate on what the problem might be. It wasn't long ago that there was a largely reported black-screen problem that was resolved mostly by using/replacing the HDMI cables being used (did you know you're not supposed to bend, or coil HDMI cables the same way you probably would with every other cable?).
Other than that, the majority of these issues have two things in common; 1. They are happening 99% on OEM systems, and 2. They are all running our hardware. The issue may very well be one of these things, but may also be an issue with the displays or cables. That's why we need to get ahold of a known-failing system in order to diagnose the problem. If it's an issue with the BIOS or video-BIOS, we can figure that out with the failing system. If it's an issue with our driver, we can pinpoint the problem, but only with a failing system. If it's the cables/display, it's probably the easiest to diagnose, but most impossible to correct as there are an infinite amount of displays on the market with non-modifiable software.
Hope this was a bit of insight for you - and I hope we can get ahold of a failing system soon!
-Nic
Can't send my system off to you guys, but if you like to send an engineer over, feel free to do so. Located in Australia. System available during the day, not in the evenings.
Cheers.
Here is my dxdiag report. Have you guys bought a system configuration as it is used and posted by some users here? For example, just buy an ASUS UX31A as I have and I'm pretty sure you'll be able to reproduce the error?!
System Information
Time of this report: 3/18/2013, 23:55:19
Machine name: privacy please 😉
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
Language: German (Regional Setting: German)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: UX31A
BIOS: BIOS Date: 05/09/12 19:32:33 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3982MB RAM
Page File: 2691MB used, 5270MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_15171043&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (40Hz)
Monitor Name: PnP-Monitor (Standard)
Monitor Model: unknown
Monitor Id: CMN1343
Native Mode: 1920 x 1080(p) (60.001Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2932 (English)
Driver Version: 9.17.10.2932
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 12/14/2012 02:42:34, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-4DE3-1535A0C2C535}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x15171043
Revision ID: 0x0009
Driver Strong Name: oem59.inf:Intel.Mfg.NTamd64:iIVBM0:9.17.10.2932:pci\ven_8086&dev_0166
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IM...
I found this thread which is the same problem I am having:
This has to be a software issue, since the display is totally fine before windows loads, everything from bios including the windows loading screen is fine. Also, when I install the driver, half-way through the driver setup, my 2nd display gets recognized and the display is active. So this can't be a cable issue, but has something to do with the software/driver under windows. In this case, users from Windows 7 and Windows 8 are both experiencing this problem.
My question is, during the driver installation, 'what' triggers the display to work? It happens exactly in the same phase during the driver installation. Perhaps, if we can create a small program which can just perform that trigger action, that would be great. So instead of having to reinstall the driver every time I connect to my 2nd display, I can just run the trigger program. I can record my driver installation to indicate at what stage the display gets recognized, will that be useful?
NICHOLAS_F_Intel
@globe_trotter: If only it were that simple... we've already purchased a system (an Asus* UX31A specifically) not too long ago in an attempt to reproduce the problem. However the system we received did not show the problem, regardless of which driver we used. It worked perfectly fine, which is the reason we need to get ahold of an actual user system that is experiencing the problem.
@Ahmad: If you can provide a video of your display-failure during the install, that'd be cool. There are a few other factors at work though, aside from the cable that might result in the issue, such as display firmware/drivers too.
-Nic
Hi nic
I can confirm the following: if I connect my UX31A via mini HDMI to the TV and boot, I get the "windows loading" logo on the TV screen for a few seconds, afterwards, windows seems to load the driver or whatever, and there is no more signal on the TV screen.
If you're not able to reproduce the error, why not sending an engineer over for records?
Or: I'm willing to send over my UX31A if you replace it by the same (same keyboard, need QWERTZ) plus some goodies 😉
BR, globe_trotter
I'd like to contribute to this discussion.
I am experiencing this exact problem for as long as you've known about it and have been posting in this thread about it. I am running an Acer Aspire V3-771G. I have run Windows 7, Windows 8 (with ClassicShell,) Arch Linux and Ubuntu 12.04 on this machine. On all of those platforms, this issue had come up in some way or another.
globe_trotter is correct in how this situation plays out. But, along with that issue, in all the time spent on Linux installed on this machine, graphics have been strange. HDMI output is the only output recognized by linux, until you have the OS fully installed, and you can change monitor settings (changing resolutions around until the desired res. was selected was what I did.)
My main point in all this is that I have a friend with a Lenovo laptop with just HD 4000 graphics installed, and no dedicated graphics card. He can easily output to HDMI. The difference between his machine and mine is that, along with HD 4000, my laptop is equipped with NVidia Optimus graphics tech. Seems like, a machine devoid of that will not experience this issue, but, with that equipped, there are issues. Can others with the discussed problem say whether their machines have Optimus installed?
Wiki article on Optimus: http://en.wikipedia.org/wiki/Nvidia_Optimus Nvidia Optimus - Wikipedia, the free encyclopedia
Hi
No Optimus installed on my Ultrabook, just Intel Graphics HD 4000.
Greetings from Austria,
I'm expiriencing the same issues with a setup I built for a friend of mine:
http://geizhals.at/gigabyte-ga-h77n-wifi-sockel-1155-dual-pc3-12800u-ddr3-a838138.html Gigabyte GA-H77N-WIFI, H77 (Sockel-1155, dual PC3-12800U DDR3)
http://geizhals.at/g-skill-dimm-kit-8gb-pc3-10667u-cl9-9-9-24-ddr3-1333-f3-10600cl9d-8gbnt-a598574.html G.Skill DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (F3-10600CL9D-8GBNT)
http://geizhals.at/intel-core-i3-3225-bx80637i33225-a766342.html Intel Core i3-3225, 2x 3.30GHz, boxed (BX80637I33225)
http://geizhals.at/samsung-ssd-840-series-120gb-mz-7td120bw-a841499.html Samsung SSD 840 Series 120GB, 2.5", SATA 6Gb/s (MZ-7TD120BW)
Before installing the intel drivers there is no issue! Both DVI-D and HDMI are working without any problems.
After installing the intel drivers, I need to disable and re-enable the driver via Windows 7 Device Manager.
The dual-head config works until the next reboot of the system.
NICHOLAS_F_Intel
Hi Tom,
Can you post a copy of the systems dxdiag please? (Start -> Run -> dxdiag -> Save All Information). Also, what displays are you connecting to? Are you only experiencing a black-screen on the HDMI connection, or the DVI as well?
-Nic
Hi nic,
as a matter of fact I can't...I don't have any access to the system right now and I won't until friday.
The first Screen is a Samsung Syncmaster 22" monitor
The second a 42" Flat-Screen from LG
Since there are already 6 pages with users having problems and it's pretty clear to all of us, that there _IS_ a problem with the driver, when can we expect a fix for this?
The thread was startet over 2 months ago and you guys weren't able to reproduce the problem? oh come on!
A pretty weak performance for a company like Intel....
Thanks Tom Zed for raising this!
I totally agree, it is not the performance that users expect from Intel.
I offered various options (sending my Ultrabook for an exchange and some goodies) or they can send an engineer over, but obviously the interest of Intel is not that high as no of the offers were considered.
Which is good for AMD in the end I guess. I seriously will have a more detailed look on AMD ultrabooks as well if I have to buy a next one.
I start to lose patience and I think I'm not the only one.
Cheers
NICHOLAS_F_Intel
@paschdan: Thanks for the information. We'll track it along with the other user configurations having the issues.
@Tom Zed: Out of the past 6 pages, there are about 35 users experiencing similar black screen issues. However, not a single one of them has occurred on an Intel® system that is NOT a NUC (different issue). If we could get it reported about an Intel® board, I can personally test the issue for reproduction. However, since the systems experiencing the problem are not Intel® systems, I don't have immediate access to their configurations. At this point we are trying to get one of the failing OEM systems in our hands so that we can identify what the disconnect is between the Intel® hardware, the drivers, and the OEM hardware. Currently we have not been able to get ahold of any failing hardware configurations.
@globe_trotter: We need an entire failing configuration in order to reproduce the problem. We can't half-do it with just the system having the issues, we need the system, the display, and all the hardware in between. Thank you for your offer - let me know if the entire setup becomes available.
-Nic
Not an Intel System!?
http://www.intel.com/content/www/us/en/architecture-and-technology/hd-graphics/hd-graphics-video.html http://www.intel.com/content/www/us/en/architecture-and-technology/hd-graphics/hd-graphics-video.html
It's called INTEL HD and not ASUS, ASRock or Gigabyte.
Your Chip, your driver software and 35 Users with different manufactures and the _SAME_ onboard graphic. YOUR GRAPHIC CHIP!
I don't need to be vulcan to see the logical explanation in this...
NICHOLAS_F_Intel
By Intel® system I am referring to one that uses an Intel® processor and an Intel® motherboard. Those are the system we develop and test, as well as the system we have access to for troubleshooting purposes. By non-Intel® system, I am referring to one that (may) use an Intel® processor, but the CPU itself is adopted onto OEM hardware (such as Asus*, GIgabyte*, or ASRock*). We do not readily have those system available to use for troubleshooting purposes.
Even if we did though, the same configuration is not guaranteed to have the problem, as I previously stated when we attempted to reproduce the issue using an Asus* UX31A (which we obtained after being told they were reliably causing the problem - they were not). This is why it is important for us to be able to obtain a complete user setup that is experiencing the problem (display, system, cable). We cannot identify the problem on a system that doesn't produce the issue, we can only do it on a system that does experience the problem. So far we do not have any complete, failing-configurations with which to test.
I would ask again that if anyone in this thread has a complete system they are willing to provide (again, complete = display, cable, system) we will research and hopefully diagnose the issue. Send me a private message if you feel your system is a failing configuration and you would like to see the problem fixed.
Thank you,
-Nic
Whatever...
Fixed it by deinstalling the _INTEL_ driver for the _INTEL_ graphic chip.
Displays work as expected with standard Windows 7 drivers...since my friend doesn't need any graphic power that seems like a fair compromise to me.
I don't want to waste any more time to this issue. Really got better stuff to do...
Hello, I'm having the same Issues with the following specs:
PC: Lenovo ThinkCentre M72E, Windows8
Monitor 1: Samsung SyncMaster S24B350 (Connected to VGA)
Monitor 2: Samsung SyncMaster S24B350 (Connected to DVI via DVI2HDMI adapter -> HDMI Cable -> HDMI IN in Monitor)
Without reneabling the graphics card my second Monitor is not recognized.
Here are my DxDiag logs:
1: Before Reenabling the Graphics Card
------------------ System Information ------------------ Time of this report: 3/25/2013, 18:42:12 Machine name: PASCHDAN-LENOVO Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130108-1504) Language: German (Regional Setting: German) System Manufacturer: LENOVO System Model: 0896B4G BIOS: F1KT45AUS Processor: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz (4 CPUs), ~3.2GHz Memory: 8192MB RAM Available OS Memory: 8014MB RAM Page File: 1916MB used, 7313MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 11 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled DxDiag Version: 6.02.9200.16384 64bit Unicode ------------ DxDiag Notes ------------ Display Tab 1: No problems found. Sound Tab 1: No problems found. Input Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: Intel(R) HD Graphics Manufacturer: Intel Corporation Chip type: Intel(R) HD Graphics Family DAC type: Internal Device Type: Full Device Device Key: Enum\PCI\VEN_8086&DEV_0152&SUBSYS_308C17AA&REV_09 Display Memory: 1760 MB Dedicated Memory: 128 MB Shared Memory: 1632 MB Current Mode: 1920 x 1080 (32 bit) (60Hz) Monitor Name: PnP-Monitor (Standard) Monitor Model: S24B350 Monitor Id: SAM08D9 Native Mode: 1920 x 1080(p) (60.000Hz) Output Type: HD15 Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32 Driver File Version: 9.17.0010.2932 (English) Driver Version: DDI Version: 11 Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1 Driver Model: WDDM 1.2 Graphics Preemption: DMA Compute Preemption: Thread group Driver Attributes: Final Retail Driver Date/Size: 12/14/2012 02:42:34, 12615680 bytes WHQL Logo'd: n/a WHQL Date Stamp: n/a Device Identifier: {D7B78E66-4212-11CF-6E7F-8610B7C2C435} Vendor ID: 0x8086 Device ID: 0x0152 SubSys ID: 0x308C17AA Revision ID: 0x0009 Driver Strong Name: oem9.inf:5f63e534c477ad23:iIVBD0:9.17.10.2932:pci\ven_8086&dev_0152 Rank Of Driver: 00E02001 Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend D3D9 Overlay: Supported DXVA-HD: Suppo...
Hi Everybody. Today I have experienced the same problem that all of you have. So Here is my computer information and dx.diag . I hope there will be a solution for this. Thanks.
Computer:Acer Aspire V3-571G
Dx.diag:
System Information
Time of this report: 3/27/2013, 21:59:56
Machine name: ACER
Operating System: Windows 8 Single Language 64-bit (6.2, Build 9200) (9200.win8_gdr.130108-1504)
Language: Turkish (Regional Setting: Turkish)
System Manufacturer: Acer
System Model: Aspire V3-571G
BIOS: V2.09
Processor: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 16384MB RAM
Available OS Memory: 16200MB RAM
Page File: 2573MB used, 15930MB available
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_06471025&REV_09
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Genel PnP Monitör
Monitor Id: AUO22EC
Native Mode: 1366 x 768(p) (60.013Hz)
Driver Version:
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-5871-4A26B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x06471025
Revision ID: 0x0009
Driver Strong Name: oem4.inf:5f63e5341859ec8c:iIVBM0:9.17.10.2932:pci\ven_8086&dev_0166
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IM...
Hello everyone!
I read this thread for a while and since i saw nothing new around...i started making my voice heard. I also realized that there is some problem with the hdmi output from the integrated video card. So even if I have a Pentium G2020 with Intel 2500 Graphics the problem still persists on this model also. I even sent back my display to the manufacturer because of this issue(thinking that's the problem). I have 1 month since i'm dealing with it. HDMI works "from time to time" the signal starts only in specific situations (when he wants). Sorry of being rude but i think there's no interest in getting this job done. My main issue with the video card is that it doesn't let my monitor go in standby mode. It's always flashing the "going to standby mode" message in a loop. I tested the display with a PNY Geforce 8500GT, no problem found. I can provide you any kind of information that can be used in tracking the wrong code. I put my trust in Intel for getting things done shortly.
Constantin
I belive I'm also having this problem. I'm trying to connect my laptop (ASUS K55VM-SX078V) via HDMI cable (direct connection) to my TV (Grundig 32 VLC 9141 T2). Neither of the two devices recognize the other. When I installed the latest Intel HD Graphics 4000 driver the PC recognized the TV (a second display named something like '2. GRUNDIG TV' was present in 'Control Panel\All Control Panel Items\Display\Screen Resolution') BUT the TV still didn't get any signal despite trying various alternatives such as changin resolution, cloning display, extending display etc. After reboot again neither device recognized the other.
Here is the information from dxdiag:
System Information
Time of this report: 4/5/2013, 14:01:31
Machine name: MARTIN-ASUS
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
Language: Swedish (Regional Setting: Swedish)
System Model: K55VM
BIOS: BIOS Date: 03/13/12 18:19:21 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz (8 CPUs), ~2.3GHz
Memory: 8192MB RAM
Available OS Memory: 8078MB RAM
Page File: 3418MB used, 12735MB available
User DPI Setting: 96 DPI (100 percent)
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_14471043&REV_09
Monitor Name: Generic PnP Monitor
Monitor Id: SEC324A
Native Mode: 1366 x 768(p) (60.023Hz)
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3071 (English)
Driver Version: 9.18.10.3071
DDI Version: 11
Driver Date/Size: 3/19/2013 21:31:48, 8647680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-0C78-4D34B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x14471043
Revision ID: 0x0009
Driver Strong Name: oem41.inf:Intel.Mfg.NTamd64:iIVBM0:9.18.10.3071:pci\ven_8086&dev_0166
{5A54A0C9-C7EC-4BD9-8EDE-F3C...
Hey guys, one more user with the same problem:
Install Intel drivers > 2.cnd monitor (BenQ V2200) comes on.
Reboot > Black screen, no where to chose a seconday monitor in Intel Graphics
Install driver again > 2.cnd monitor comes on.
I'm not going to post that huge system dump file, becase I doubt it will help at this point, how ever my system is:
Asus Zenbook Prime (UX31A) running windows 8 64bit.
Pleeeeaaase fix this intel!
