22958 Discussions
"Out of video memory trying to allocate a texture!" error when playing Valorant
Alexnz
Hello, I have been having an issue while play valorant recently where valorant crashes and an error message appears saying...
"Out of video memory trying to allocate a texture! Make sure your video card has the minimum required memory, try lowering the resolution and/or closing other applications that are running. Exiting..."
I Have found a thread where the user reset is laptop and it worked but what would happen if i were to reset a pc instead of a laptop.  Would it fix it?
Steven_Intel
Hello Alexnz,
I am sorry you are having issues with your Intel graphics.
In order to better assist you, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
SiniuKot
Hello, I have a similar situation. File as an attachment
Could you tell me what the problem is and how to solve it?
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
