22796 Discussions
render.lighttilecspathenable causing lights flickering(Battlefield 2042)
Wincek
Hello, I have discovered that this factor is causing lights flickering in game which makes playing painful for eyes. I can disable it but then it makes menu skins dark and colourless. I was getting help with it by ea support however they said it's because my graphic card so I ask for help with it here. My GPU is Intel Arc B570 and cpu is i5-14400f.
JeanetteC_Intel
Hello Wincek,
To help troubleshoot this issue, could you please provide the following information:
  1. Please check your Intel Arc graphics driver version in Device Manager or Intel Arc Control
  2. Are you only experiencing this issue with Battlefield 2042 or are there any other games affected?
  3. What graphics quality settings are you currently using in-game? Kindly share screenshot.
  4. Kindly share your monitor model, resolution, and refresh rate you're using.
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply
JeanetteC.
Wincek
1. I have checked 3 last driver versions but they all have the same issue.
2. I haven't yet experienced this problem on any other game however i have found this issue had some other person in different game here https://forums.flightsimulator.com/t/flickering-on-intel-arc-gpu/708770
3. Well I am using all ultra settings but tried a lot of configurations including the lowest one however they didn't solve this issue.
4. It's iiyama g-master ge2488hs, 1920x1080 and 60 hz
JeanetteC_Intel
Hello Wincek,
Thank you for providing the requested information. To help troubleshoot further, please share the following additional details:
1) Please confirm if the other two affected driver versions, besides the currently installed 32.0.101.8132 (WHQL Certified), are:
2) Please provide a screenshot of your in-game settings
3) Please share your power supply unit (PSU) make and model
JeanetteC.
Wincek
1) Yes, I have tried them all
2) I add a video in attachment.
3) It's 10A 250V
Wincek
3) It's only power supply cable but i was told at service that my PSU is enough for my PC
JeanetteC_Intel
Hello Wincek,
Thank you for providing all the requested details. I'll review this information internally and provide you with an update as soon as it becomes available.
JeanetteC.
JeanetteC_Intel
Hello Wincek,
While I prepare to replicate this issue, please:
This will help with our troubleshooting process.
I look forward to your reply.
JeanetteC.
VonM_Intel
Hello Wincek,
JeanetteC.
VonM_Intel
Hello Wincek,
I just wanted to check in. Have you had a chance to review my previous message regarding the driver updates and BIOS ReBar status? Please let me know if you’ve had an opportunity to try those steps or if you need any additional guidance. I’m here to help and would be glad to continue troubleshooting with you.
Von M.
Wincek
Sorry for late response,
Yes I have enabled ReBar and tried both suggested drivers but unsuprisigly problem with lights still occurs
JeanetteC_Intel
Hello Wincek,
I'd like you to try installing the latest driver version 32.0.101.8136. Please use DDU in safe mode to ensure a clean installation, then test to see if the issue is resolved.
Please keep me updated on the results.
JeanetteC.
Wincek
It's still the same. Also, I have found similar case in Battlefield 4 that I attach here
DeancR_Intel
Hello Wincek,
Thank you for providing this clip for me to further investigate this flickering issue. I will be checking this internally and get back to you once I have the information you need.
Dean R.
JeanetteC_Intel
Hello Wincek,
This issue is still under investigation. To help us troubleshoot further, could you share the exact steps that trigger the problem? Our lab testing hasn't reproduced the same behavior yet.
Additionally, please specify which mode you're experiencing this in.
Thanks for your patience.
JeanetteC.
JeanetteC_Intel
Hello Wincek,
Did you have a chance to review the previous post?
Please feel free to reach out if you have any questions.
JeanetteC.
