23525 Discussions
resolution 1080 x 1080
Neiken
Generally, I play Counter Strike Global Offensive and I have a problem with having a resolution of 1080 by 1080 and, for example, on nvidia graphics cards it is done in the control panel and I cannot find on the Internet how to do it on an integrated graphics card from Intel (integrated graphics card for i3 1005g1) (this is what it looks like on an invidia graphics card https://www.youtube.com/watch?v=kesjBOVXn2s)
Jean_Intel
Hello Neiken,
Thank you for posting in the Intel Communities. We would be more than glad to help you with your resolution problem when playing Counter Strike Global Offensive.
To better assist you, please provide us with the following:
  • Are you looking to set the 1080x1080 resolution as a custom resolution?
  • Are you using an external monitor?
  • Create a report using the Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello Neiken,
We hope you are doing fine.
Were you able to check the previous post? Let us know if you still need assistance.
Jean O.
Jean_Intel
Hello Neiken,
Best regards.
Jean O.
