- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I just bought a HP Prodesk G1 DM with HD graphics 4600, but I cannot have a 3840x2160 60hz, but only 30 maximum.
DP/DP cable with AOC 2777 screen
Windows 10 pro
driver 20.19.15.5126 from 21/11/2020
It is the same driver that my Fujitsu Esprimo with hd4600 too and it works on the Fujitsu
Someone can help me?
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Aurelien,
Thank you for posting on the Intel* Community.
To better assist you, please provide us with the below information:
- Do you use the same cable/connection DP to DP with the Fujitsu?
Intel® System Support Utility (Intel® SSU)
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
With the external display connected, provide the Intel* Graphics Command Center report:
>Go to the Intel Graphics Command Center
>Support
>System Diagnostic
>Generate report.
>Attach the report file.
Maria R.
- Теги:
- I've been at this for weeks!! They can open cases all day long. They've blatantly lied about the HD 4600 Graphics card!
- SteveMack
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Maria,
For sure I used the same cable and screen. Moreover I have just tested with a mini Dell computer (with HD graphics 530) and I have the 3840x2160 @ 60hz resolution available and it works.
Here you have the reports.
I didn't understand the second tip: ’Intel Graphics Command Center, I didn't find this, only the options and assistance of the graphics panel
I Hope it can help
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Intel Graphics Command Center (IGCC) is the new app for configuring the operation of the iGFX engine when DCH-architected drivers are used. It is automatically downloaded from the MS App Store and should appear in the Windows Start Menu. The old Intel Graphics Control Panel (IGCP), which was invoked from the Context Menu, has been EOLed.
Hope this helps,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I have downloaded the IGCC but I cannot have the report, see attached picture
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
As I said, IGCC is for graphics drivers that are DCH-architected. The drivers for your graphics adapter are NOT DCH-architected, so you should use the old Intel Graphics Control Panel app, which you can invoke from the right-click context menu.
Also from the right-click context menu, you can use the Display Settings shortcut to get to the appropriate Settings scene. You can also bring up Settings directly from the Start Menu and then browse to System and then Display.
Once you are in the Display Settings scene, click on the Advanced display settings link and then check if the 60Hz entry is available in the Refresh Rate field. I have seen situations where it defaults to 30Hz when connecting the monitor but can be advanced to 60Hz after the fact.
Hope this helps,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
No, 60hz is not available, it is the first thing I made...the maximum rate is 30hz
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I am not sure of the answer. In my testing today, a DisplayPort to HDMI adapter that supports 4K@60Hz when plugged into 6th gen NUCs, but will only support 4K@30Hz when plugged into 4th and 5th gen NUCs. The specs for the DisplayPort port are identical in the processor specs of all three processor generations.
Intel Customer Support will need to step in here and investigate why this is the case.
@Maria_R_Intel, @Sebastian_M_Intel, @Alberto_Sykes, @Ronny_G_Intel, someone please own it.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Scott,
here you have the copy of my Fujitsu computer, with the same graphics, cable and screen
resolution 3840x2160 at 60hz is ok with a fourth generation.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
That's great; not the result I am seeing.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Aurelien,
We noticed that you have contacted Intel® Customer Support directly regarding the same issue here described and we found out that you have an internal support case open. In this case, we will proceed to close this thread to avoid duplication of effort and the support will continue through the internal case.
Maria R.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
