23274 Discussions
running windows 7, system does not see 2cnd monitor, (tv) connected via display port to HDMI
ggreg8
I dont understand why not
Hi Tapemeasureman,
I will need to collect more information before providing any troubleshooting. Please tell me if this video adapter was working before with the same pc and monitor.
Also, send to me the results of Intel® System Support Utility.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
How to attach a file:
-Click on reply
-Click Use advanced editor (upper right side)
-Click Attach (lower right hand)
Mike C
ggreg8
Thanks,Mike
No it is a new "refurb" from Microcenter. I bought one ( identical ) last
week and returned it for the same problem. Picked up another yesterday.
Before I left the store I made them hook it up, 1 st using VGA plug worked
fine. Tech support did not have a display port to HDMI adapter, but did
have a DP to VGA adapter. Again it worked fine, video anyway, we didnt
check for audio, and thats not a concern. The DP to HDMI adapter I have
worked fine on my last Lenovo .desktop, although it seems to me I may have
had the same problems initially when I got that one 2-3 years ago. Im
pretty sure I had this issue back then. I just changed out my HDMI cable
for a brand new one so its not that. I dont have another working unit with
a DP out plug to test out the adapter. In the Intel control panel, it tells
me monitor and TV settings are not supported.....
Thanks for your timely response
Gregg
Hi Tapemeasureman,
I reviewed your system configuration and you already have the latest graphics driver 2869 for Q45 chipset. Intel stopped supporting it sometime ago, no more drivers were released.
According to the error message, I recommend you to make a test changing manually the TV resolution (from TV settings).
Also, verify at Hewlett Packard if you already have the latest BIOS and chipset drivers.
http://support.hp.com/us-en/drivers http://support.hp.com/us-en/drivers
If problem continues, it will be necessary to test your system with a second video adapter.
Regards,Mike C
