HI,
I have got a new miniPC PN64 and the task bar is quite invisible on my TV (16/9). the graphic card is an Iris Xe integrted. How can I resize the picture ?
Thank you
Hello @brimballe
Please download and install Intel® Graphics Command Center (Beta) and go to Display > General > Scale > Custom. There you can create your own profile.
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Have you asked the manufacturer for assistance? If not, you should.
Hello @brimballe
Jose B.
Hello brimballe,
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
