23062 ディスカッション
two monitor
leo_avelar
ビギナー
4,930件の閲覧回数
good afternoon, i need to know if you can use my notebook and a monitor simultaneously for games and other things. I need something like what Nvidia Surround does, but from intel.
0 件の賞賛
8 返答(返信)
AlHill
スーパーユーザー
4,923件の閲覧回数
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
leo_avelar
ビギナー
4,916件の閲覧回数
Está bem, @AlHill
n_scott_pearson
スーパーユーザー
4,911件の閲覧回数
Your laptop has a HDMI port that can be used to connect a single external monitor. This HDMI monitor would be limited to 4K@30Hz or 2K@60Hz .
leo_avelar
ビギナー
4,893件の閲覧回数
my notebook is already connected to an external monitor, however when I go to extend it appears two different screens independently, I want to use them simultaneously, as Nvidia sorround (gives a research on what it is)
n_scott_pearson
スーパーユーザー
4,885件の閲覧回数
Ah, now I understand what you're after. Open Intel Graphics Command Center, select Display and then enable Combine Desktops.
leo_avelar
ビギナー
4,882件の閲覧回数
I want to know how to do it from here
n_scott_pearson
スーパーユーザー
4,876件の閲覧回数
Huh? I have no idea what you are asking. Do exactly what I said. Intel Graphics Command Center is a Modern GUI (Metro) app, so accessed from Start menu.
marktbaker84
ビギナー
4,833件の閲覧回数
To enable extended desktop mode in the Intel Graphics Control Panel:
  1. From the Windows Start Menu, search for the Intel Graphics Control Panel. Double click the Intel® Graphics Control Panel 💻 icon.
  2. Click Display > Multiple Displays🖥🖥💻
  1. Select Extended Desktop mode and click Apply.
For some systems, with third generation or newer Intel® Core™ Processors, three-display support  is available. After completing the previous steps:
  1. Use the Arrange Displays window. Use your mouse to move the displays in a different arrangement.
  2. Click Apply to save changes😉.
返信
