22747 Discussions
uhd 730
yuksel
hello my screen, in the 30 series version, the signal cuts off from time to time and the image turns off, it takes 2 seconds. then when i upgrade to 31 series version, this time my max resolution drops from 4K to 2K
Steven_Intel
Hello yuksel,
I am sorry you are having issues with your Intel® UHD Graphics 730, I will be glad to help.
Please provide the following information:
  • Are you using a desktop system? If that is the case, what is the model of your monitor/TV?
  • Have you tried a different cable and/or monitor?
As well, please perform a clean installation of the latest driver v31.0.101.4314 (https://www.intel.com/content/www/us/en/download/726609/intel-arc-iris-xe-graphics-whql-windows.html?). Make sure to follow the clean installation instructions: https://www.intel.com/content/www/us/en/support/articles/000057389/graphics.html
If the issue persists, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
yuksel
yes i am using desktop i have changed hdmi cable. i am using hdmi 2.1 cable and my monitor is 'asus vg289q1a' Version:31.0.101.4314 and Version: 31.0.101.4335 I tried both of them and again the maximum resolution remained at 2K. I don't want to do a clean install because I can't find the setup of 30.0.101.1273 running in 4K. because if I do a clean install, I don't want to stay 2K again.
yuksel
Carlos_L_Intel
Hi @yuksel
 Thank you for all the information. Based on the reports provided, I can see that your motherboard is a Gigabyte H510M H which based on its specification has an HDMI 1.4 port which can get up to 4096x2160@30 Hz. My recommendation are:
  • Change your refresh rate to 30 hertz and select 4k
  • If this is not an option, create a custom resolution with 4096x2160 @ 30Hz, and you should be able to display at 4k.
Carlos L.
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
