22721 Discussions
when i try to install the intel Graphics driver it keeps telling me as represented in the image that's an image for the version i downloaded along with the error and my device specifications
oshaw
n_scott_pearson
What build of Windows 10 do you have installed? Is it, for example, build 1809?
What Intel HD Graphics driver package are you attempting to install? What is the name of the file you are downloading from the Intel site?
oshaw
Version : DCH 25.20.100.6519.exe released in 1/17/2019
windows build : 15063
intel graphics card is : 630 HD That attached To i5-7500 (3.4 Or 3.6)(i don't remember exactly) GHz Processor
n_scott_pearson
The DCH drivers are intended for use with the 1809 release of Windows 10 You are using a previous release. Upgrade to the latest release and then follow previous instructions for installing the DCH driver. If you are going to stick with the old release, then don't attempt to use the DCH-based driver versions (of course, this will cut you off from all future driver fixes as all releases moving forward will be DCH-based).
