20948 Discussions
win10 upgrade probleme mit grafikkarte hd graphics 530
Markus_B
ist die Intel hd graphics 530 nicht kompatibel mit win10?
AlHill
Yes, it is compatible.
What is your processor model number?
What version of Windows 10?  1909?  2004?
Doc
Markus_B
Version 1909
Intel (R) Core (TM) i5-6400 CPU @ 2.70 GHZ 2.70 GHz
AlHill
Here, under "drivers and software", you can find the latest graphics driver for your processor:
https://ark.intel.com/content/www/us/en/ark/products/88185/intel-core-i5-6400-processor-6m-cache-up-to-3-30-ghz.html
Is your device a laptop or desktop?
Do you have dual graphics?
What is the manufacturer's model number for your device?
Doc
Markus_B
ok i will try to update
it is desktop
yes dual
Fujitsu Esprimo P557
AlHill
For the dual graphics, you have an add-on graphics card, like nvidia or amd,  correct?
Does the fujitsu bios allow BOTH the Intel graphics and add-on graphics to be active at the same time?
It is usually the case that one or the other are active, but not both.  Usually when you install an add-on card, it will disable the processor graphics.
Doc
Markus_B
I think the problem is some other device driver
