当我使用我的A750显卡运行Steam游戏库中的黑神话悟空时,在画质设置下,选择XESS时,无法开启帧生成功能,并且无法选择使用其它帧生成技术,比如FSR。
我目前使用32.0.101.6989驱动,并在几个月内尝试了十个以上的不同驱动,结果相同,我仍然无法开启XESS的帧生成功能。我甚至无法确认我的XESS版本是否在2.0以上,因为根据显示效果,它看起来更像是旧版本的XESS。
CPU:R5 7500F
电源:玄武650K
主板:微星B650M迫击炮
内存:32G
系统版本:Windows10 22H2
这个问题困扰了我几个月的时间,让我的心情很糟糕,期待您的回复,以及具体的解决方法。
希望能得到回复
Hi 门徒,
Thank you for posting in our Community. Please be informed that I can only support you in English. I have used a web translation tool to translate this response hence, there may be some inaccurate translations. At this time, Intel® XeSS (XESS) frame generation support depends on both the game’s implementation and the driver. Not all titles or versions of XeSS include frame generation, which may explain why the option is unavailable in Black Myth: Wukong.
To better assist, could you please confirm:
- The exact in-game version/build of Black Myth: Wukong you are running. (Kindly convert to the English language so I can further check it.)
- If the game received any recent patches since your last test?
- Whether you tested with the latest Windows 11 build (since some newer features are optimized there compared to Windows 10)?
I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable me to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue.
Have a nice day!
Von M.
Black Myth Generation Version ID: 18095325
Game update date: April 22, 2025
Computer System: Win10
Black Myth Wukong will support XESS2 frame generation after April 17, 2025. I have confirmed on some community platforms the running effect of XESS2 frame generation when they use A750. However, there are also some A-series graphics card users who are the same as me and cannot correctly apply XESS2 frame generation effects. Some of them are on Win10 system and some are on Win11 system, so I am very confused.
Hello 门徒,
Thank you for providing the details. I’ll need to conduct further research regarding this behavior, and I’ll provide an update in this thread once I have more information to share.
Von M.
Hello 门徒,
Thank you so much for patiently waiting while we reviewed your case. To help us reproduce and better understand the issue, could you kindly provide us with the following details:
- The exact steps you used when the issue occurred
- The native resolution of your monitor, and whether it’s connected via HDMI or DisplayPort
- Have you had the chance to test with the latest graphics driver version 32.0.101.7028? If yes, does the issue still persist?
- A list of the driver versions you’ve already tested would also be very helpful
Your input will greatly assist us in narrowing down the cause and moving closer to a resolution.
Von M.
I am using the DisplayPort interface, and the 32.0.101.7028 driver version did not solve this problem. In fact, I have tried more than ten driver versions before this, which took me a lot of time. Unfortunately, the problem did not get resolved, which is why I am here to communicate with you.
Hello 门徒,
Thank you for confirming that you are using DisplayPort and for letting us know that the issue persists even with the latest graphics driver (32.0.101.7028). We also appreciate the time and effort you’ve already put into testing multiple driver versions. I also wanted to kindly follow up, as a few of our earlier questions remain unanswered, specifically, the exact steps you take when the issue occurs, the native resolution of your monitor, and a list of the driver versions you’ve already tested. Providing these details will help us gain a clearer understanding of the problem and ensure we can share complete information with our higher-level support team.
Von M.
Monitor: Philips 252M1RPE
Resolution: 1920 * 1080
After entering the game normally, I didn't have any special settings. At first, I thought it was due to the game, so I spent some time uninstalling and reinstalling the game, but it didn't work.
Hello 门徒,
Thank you for providing the details about your monitor, resolution, and the steps you’ve already taken to troubleshoot. I’ll need to conduct some additional research on this issue to ensure we cover all possible angles. I’ll post an update in this thread as soon as I have more information to share.
Thank you for your patience and understanding.
Von M.
Thank you for your reply! When this issue is resolved, I would also like to provide feedback on some bugs that occur when running other games. Maintain communication.
Hello 门徒,
Thank you for your patience. I tested the issue and confirmed that the frame generation function is enabled when using XeSS (please see the attached file: screen recording). To help resolve the problem, I recommend updating to the latest driver version 32.0.101.7028 or newer, performing a clean installation using DDU to execute a clean insallation and remove any remnants of the old driver and application thoroughly, and reinstalling the game.
If the issue continues after these steps, please let me know so I can investigate further.
Von M.
I am on a business trip, which will take some time. When I get home, I will try the steps you told me, even if some of them are ones I have already done many times. I will give you feedback on the outcome after trying, please wait for my message.
