Hi supi,
When did the issue start? Was it after a specific driver update or game patch?
What are the troubleshooting steps that you tried so far other than updating your driver?
Is the Resizable Bar enabled?
Have you used Display Driver Uninstaller (DDU) to completely remove all residual drivers and installed a new one?
Have you tried adjusting the graphics settings?
Could you provide a screenshot of your in-game display and graphics settings in English?
Which gaming platform did you use to download the game?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
OK, ArchieD_Intel
-- I'm not quite sure because I only discovered it by chance. However, I can confirm that this issue exists in 6987 WHQL, 6989, and the latest 7026 WHQL.
-- Yes.
-- Yes, I just completely removed my old driver (32.0.101.6989) using DDU and installed the latest driver (32.0.101.7026 WHQL). The game was also updated, but the problem still persists.
-- No
-- From steam.
SSU.txt:
# SSU Scan Information
Scan Info:
Version:"4.2.0.0"
Date:"08/26/2025"
Time:"00:00:35.1212546"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. 3010 , 12/11/2023 12:00 上午"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"12th Gen Intel(R) Core(TM) i5-12400F , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.4"
Sound Card:"High Definition Audio 设备"
System Manufacturer:"ASUS"
System Model:"System Product Name"
System SKU:"SKU"
System Type:"x64-based PC"
- "Graphics"
Intel ® Graphics Driver Version:"17.13.25.697"
- "GameViewer Virtual Display Adapter"
Adapter Compatibility:"GameViewer"
Adapter DAC Type:"Not Available"
Adapter RAM:"Not Available"
Availability:"Offline"
Bits Per Pixel:"Not Available"
Caption:"GameViewer Virtual Display Adapter"
CoInstallers:"oem25.inf,MyDevice_Install.NT,Not Available,Not Available"
Color Table Entries:"Not Available"
Dedicated Video Memory:"12112 MB"
Driver:"WUDFRd.sys"
Driver Date:"05/16/2024 08:00 上午"
Driver Path:"C:\Windows\system32\drivers\WUDFRd.sys"
Driver Provider:"GameViewer"
INF:"oem25.inf"
INF Section:"MyDevice_Install.NT"
Install Date:"Not Available"
Installed Drivers:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"GameViewer"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"Not Available"
Number of Video Pages:"Not Available"
PNP Device ID:"ROOT\DISPLAY\0000"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"Not Available"
Refresh Rate - Maximum:"Not Available"
Refresh Rate - Minimum:"Not Available"
Resolution:"Not Available"
Scan Mode:"Not Available"
Service Name:"WUDFRd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"8098 MB"
Video Processor:"Not Available"
- "Intel(R) Arc(TM) B580 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) B580 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+B580+Graphics"
CoInstallers:"oem8.inf,BMG_IAG_E20B_FWU_wNext,Internal,Intel(R) Arc(TM) B580 Graphics Family"
Color Table Entries:"4294967296"
Driver:"igdkmdnd64.sys"
Driver Date:"08/19/2025 08:00 上午"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_a5316ec10b210075\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"32.0.101.7026"
INF:"oem8.inf"
INF Section:"BMG_IAG_E20B_FWU_wNext"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_a5316ec10b210075\igd9trinity64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_a5316ec10b210075\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_a5316ec10b210075\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_a5316ec10b210075\igd12umd64.dll"
Manufacturer:"Intel Corporation"
Monochrome:"No"
Number of Colors:"4294967296"
PNP Device ID:"PCI\VEN_8086&DEV_E20B&SUBSYS_21151EF7&REV_00\6&1567D419&0&00080008"
Refresh Rate - Current:"180 Hz"
Refresh Rate - Maximum:"180 Hz"
Refresh Rate - Minimum:"50 Hz"
Resolution:"2560 X 1440"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Processor:"Intel(R) Arc(TM) B580 Graphics Family"
- "Management Engine"
- "vPro"
Intel Active Management technology (AMT):"Not Detected"
- "Memory"
Physical Memory (Available):"8.13 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15.82 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"Controller0-ChannelA-DIMM0"
Configured Clock Speed:"2666 MT/s"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"KingBank"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"Not Available"
Serial Number:"02120212"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"8 GB"
Channel:"Controller1-ChannelA-DIMM0"
Form Factor:"DIMM"
Interleave Position:"Second position"
Type:"Synchronous"
- "Motherboard"
BIOS:"3010, ALASKA - 1072009"
Caption:"主板"
Chipset:"Not Available"
Date:"12/11/2023 12:00 上午"
Model:"Not Available"
PNP Device ID:"Not Available"
Product:"PRIME H610M-A D4"
Serial Number:"240233597900300"
Status:"OK"
Version:"Rev 1.xx"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.26100.4061"
Index:"0013"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"08/26/2025 05:21 下午"
MAC Address:"08:B4:D2:49:F5:BF"
Manufacturer:"Microsoft"
Net Connection ID:"蓝牙网络连接"
NetCfgInstanceId:"{D93FFFAE-0D8E-4270-9E44-2BE8E12ECC0B}"
PNP Device ID:"BTH\MS_BTHPAN\6&136D0F65&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"以太网 802.3"
- "Service Bindings"
链路层拓扑发现响应程序:
链路层拓扑发现映射器 I/O 驱动程序:
Internet 协议版本 4 (TCP/IPv4):
Internet 协议版本 6 (TCP/IPv6):
Microsoft 网络的文件和打印机共享:
Microsoft 网络客户端:
Microsoft LLDP 协议驱动程序:
VMware Bridge Protocol:
- "iNode VPN Virtual NIC"
Caption:"iNode VPN Virtual NIC"
DHCP Enabled:"No"
Driver:"inodevnic.sys"
Driver Date:"02/20/2013 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\inodevnic.sys"
Driver Provider:"H3C"
Driver Version:"1.0.0.0"
Index:"0016"
INF:"oem27.inf"
INF Section:"NetVMini.ndi"
Installed:"Yes"
MAC Address:"02:50:F2:00:00:02"
Manufacturer:"H3C"
Net Connection ID:"iNode VPN"
NetCfgInstanceId:"{B131D09C-D249-4D7E-8ADF-40CFFF903AE2}"
PNP Device ID:"ROOT\NET\0000"
Product Type:"iNode VPN Virtual NIC"
Service Name:"NetVMini"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
嵌套网络虚拟化:
桥驱动程序:
Microsoft 网络客户端:
QoS 数据包计划程序:
- "Intel(R) Ethernet Connection (17) I219-V"
- "Caption":"Intel(R) Ethernet Connection (17) I219-V"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Connection+(17)+I219+V"
DHCP Enabled:"Yes"
Driver:"e1d68x64.sys"
Driver Date:"06/22/2021 12:00 上午"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\e1d68x64.inf_amd64_b32d0891eb98aee4\e1d68x64.sys"
Driver Provider:"Intel"
Driver Version:"12.19.1.37"
ETrackID:"Not Available"
Index:"0000"
INF:"oem47.inf"
INF Section:"E1A1D.10.0.1.19H1"
Installed:"Yes"
MAC Address:"10:7C:61:79:6F:A1"
Manufacturer:"Intel"
Net Connection ID:"以太网"
NetCfgInstanceId:"{48A4EE20-0203-4642-ADAF-4E8084A76BD8}"
NVM Version:"Not Available"
Part Number:"FFFFFF-0FF"
PNP Device ID:"PCI\VEN_8086&DEV_1A1D&SUBSYS_86721043&REV_11\3&11583659&0&FE"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Ethernet Connection (17) I219-V"
Service Name:"e1dexpress"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
嵌套网络虚拟化:
桥驱动程序:
Microsoft 网络客户端:
QoS 数据包计划程序:
- "Settings"
*FlowControl:流量控制:"已启用 Rx 和 Tx (3)"
*InterruptModeration:中断裁决:"启用 (1)"
*IPChecksumOffloadIPv4:IPv4 校验和分载传输:"已启用 Rx 和 Tx (3)"
*JumboPacket:巨帧数据包:"禁用 (1514)"
*LsoV2IPv4:大型发送分载 V2 (IPv4):"启用 (1)"
*LsoV2IPv6:大型发送分载 V2 (IPv6):"启用 (1)"
*ModernStandbyWoLMagicPacket:在收到魔包时从 S0ix 状态唤醒 :"启用 (1)"
*NumRssQueues:RSS 队列的最大数目:"2 个队列 (2)"
*PMARPOffload:协议 ARP 分载:"启用 (1)"
*PMNSOffload:协议 NS 分载:"启用 (1)"
*PriorityVLANTag:数据包优先级和 VLAN:"已启用数据包优先级和 VLAN (3)"
*PtpHardwareTimestamp:PTP 硬件时间戳:"禁用 (0)"
*ReceiveBuffers:接收缓冲区:"256 (256)"
*RSS:接收方调整:"启用 (1)"
*RSSProfile:RSS 负载平衡配置式:"最近的处理器 (1)"
*SelectiveSuspend:选择性暂停:"启用 (1)"
*SoftwareTimestamp:软件时间戳:"禁用 (0)"
*SpeedDuplex:速度和双工:"自动协商 (0)"
*SSIdleTimeout:选择性暂停空闲超时:"20 (20)"
*TCPChecksumOffloadIPv4:TCP 校验和分载传输 (IPv4):"已启用 Rx 和 Tx (3)"
*TCPChecksumOffloadIPv6:TCP 校验和分载传输 (IPv6):"已启用 Rx 和 Tx (3)"
*TransmitBuffers:传输缓冲区:"512 (512)"
*UDPChecksumOffloadIPv4:UDP 校验和分载传输 (IPv4):"已启用 Rx 和 Tx (3)"
*UDPChecksumOffloadIPv6:UDP 校验和分载传输 (IPv6):"已启用 Rx 和 Tx (3)"
*WakeOnMagicPacket:唤醒魔包:"启用 (1)"
*WakeOnPattern:唤醒模式匹配:"启用 (1)"
AdaptiveIFS:适应性帧间距调整:"禁用 (0)"
AutoPowerSaveModeEnabled:链接速度电池节能:"禁用 (0)"
EEELinkAdvertisement:节能以太网:"开启 (1)"
EnablePME:启用 PME:"启用 (1)"
ITR:中断裁决率:"适应性 (65535)"
LinkNegotiationProcess:传统型交换器兼容模式:"禁用 (1)"
LogLinkStateEvent:记录链接状态事件:"启用 (51)"
MasterSlave:千兆位主从模式:"自动检测 (0)"
ReduceSpeedOnPowerDown:电源关闭时降低速度:"启用 (1)"
SipsEnabled:系统闲置电源节能:"禁用 (0)"
ULPMode:超低功耗模式:"启用 (1)"
WaitAutoNegComplete:等待链接:"自动检测 (2)"
WakeOnLink:链接唤醒设置:"禁用 (0)"
- "Intel(R) Wi-Fi 6 AX101"
Access Point:
Authentication:
- "Caption":"Intel(R) Wi-Fi 6 AX101"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6+AX101"
Channel:
Cipher:
Connection Mode:
Default IP Gateway:"192.168.3.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"08/27/2025 05:21 下午"
DHCP Lease Obtained:"08/26/2025 05:21 下午"
DHCP Server:"192.168.3.1"
Driver:"Netwtw14.sys"
Driver Date:"06/12/2025 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\Netwtw14.sys"
Driver Version:"23.150.0.4"
Index:"0010"
INF:"oem65.inf"
INF Section:"Install_GEN_SLR_HrP1_101_AX_no_160_1x1_WinT_non_6e"
Installed:"Yes"
IP Address:"192.168.3.90;fe80::534c:6eb:271d:33e3"
IP Subnet:"255.255.255.0;64"
MAC Address:"08:B4:D2:49:F5:BB"
Net Connection ID:"WLAN"
NetCfgInstanceId:"{C1C87D02-8F9D-4141-81B7-C61F0FC3F2E2}"
Network Name:"HUAWEI-91B5UL"
Network Type:
PNP Device ID:"PCI\VEN_8086&DEV_7AF0&SUBSYS_02448086&REV_11\3&11583659&0&A3"
Power Management (Wake On LAN):"Active: Yes, Enable: No"
Product Type:"Intel(R) Wi-Fi 6 AX101"
Profile:
Radio Type:
Receive Rate:
Service Name:"Netwtw14"
Signal Strength:
State:
Status:"Enabled"
Transmit Rate:
Type:"以太网 802.3"
链路层拓扑发现响应程序:
嵌套网络虚拟化:
桥驱动程序:
Microsoft 网络客户端:
QoS 数据包计划程序:
- "Settings"
*DeviceSleepOnDisconnect:WoWLAN 断开连接时睡眠:"已禁用 (0)"
*PMARPOffload:WoWLAN 的 ARP 卸载:"已启用 (1)"
*PMNSOffload:WoWLAN 的 NS 卸载:"已启用 (1)"
*PMWiFiRekeyOffload:WoWLAN 的 GTK 重新生成密钥:"已启用 (1)"
*WakeOnMagicPacket:唤醒幻数据包:"已启用 (1)"
*WakeOnPattern:唤醒模式匹配:"已启用 (1)"
ChannelWidth24:2.4GHz 信道宽度:"自动 (1)"
ChannelWidth52:5GHz 信道宽度:"自动 (1)"
CtsToItself:混合模式保护:"RTS/CTS 已启用 (0)"
FatChannelIntolerant:与 40Mhz 信道不兼容:"已禁用 (0)"
IbssTxPower:传输电源:"5. 最高值 (100)"
IEEE11nMode:802.11n/ac/ax 无线模式:"4. 802.11ax (3)"
MIMOPowerSaveMode:MIMO 节能模式:"自动 SMPS (0)"
RoamAggressiveness:漫游主动性:"3. 中间 (2)"
RoamingPreferredBandType:首选频带:"1. 无首选项 (0)"
ThroughputBoosterEnabled:吞吐量助推器:"已禁用 (0)"
uAPSDSupport:支持 U-APSD :"已禁用 (0)"
WirelessMode:802.11a/b/g 无线模式:"6. 双频带 802.11a/b/g (34)"
- "VMware Virtual Ethernet Adapter for VMnet1"
Caption:"VMware Virtual Ethernet Adapter for VMnet1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"08/26/2025 05:55 下午"
DHCP Lease Obtained:"08/26/2025 05:25 下午"
DHCP Server:"192.168.244.254"
Driver:"vmnetadapter.sys"
Driver Date:"06/07/2024 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\vmnetadapter.sys"
Driver Provider:"Broadcom Inc."
Driver Version:"17.6.0.0"
Index:"0015"
INF:"oem50.inf"
INF Section:"VMnetAdapter1.Install"
Installed:"Yes"
IP Address:"192.168.244.1;fe80::d3c:5cc6:331b:c725"
MAC Address:"00:50:56:C0:00:01"
Manufacturer:"Broadcom Inc."
Net Connection ID:"VMware Network Adapter VMnet1"
NetCfgInstanceId:"{87D9C765-1095-4986-AFD4-DCA08F0B703A}"
PNP Device ID:"ROOT\VMWARE\0000"
Product Type:"VMware Virtual Ethernet Adapter for VMnet1"
Service Name:"VMnetAdapter"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
- "Settings"
*JumboPacket:Jumbo Packet:"Disabled (1514) (1514)"
*PriorityVLANTag:Priority / VLAN tag:"Priority & VLAN Enabled (3)"
*WakeOnMagicPacket:Wake on magic packet:"Enabled (1)"
*WakeOnPattern:Wake on pattern match:"Enabled (1)"
EnableWakeOnLan:Wake on LAN:"Enabled (1)"
- "VMware Virtual Ethernet Adapter for VMnet8"
Caption:"VMware Virtual Ethernet Adapter for VMnet8"
DHCP Enabled:"Yes"
DHCP Server:"192.168.29.254"
Index:"0017"
INF:"oem50.inf"
INF Section:"VMnetAdapter8.Install"
Installed:"Yes"
IP Address:"192.168.29.1;fe80::e02f:f4b2:ba4:8ba5"
MAC Address:"00:50:56:C0:00:08"
Net Connection ID:"VMware Network Adapter VMnet8"
NetCfgInstanceId:"{D5591BD1-2AF9-4FC9-8F2D-789A5C540C88}"
PNP Device ID:"ROOT\VMWARE\0001"
Product Type:"VMware Virtual Ethernet Adapter for VMnet8"
Status:"Enabled"
Type:"以太网 802.3"
链路层拓扑发现响应程序:
Microsoft 网络客户端:
- "Settings"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Internet Explorer,11.1882, Microsoft Edge,139.0"
Locale:"中国"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 专业版"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"6.25 GB"
Physical Memory (Available):"8.14 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.26100 Build 26100.4770"
Virtual Memory (Available):"11.44 GB"
Virtual Memory (Total):"22.07 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2025/4/5]"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2025/4/5]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2025/4/5]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2025/4/5]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5056579:"Update [5/3/2025]"
KB5062660:"Update [8/18/2025]"
KB5065381:"Security Update [8/13/2025]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2025/4/5]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2025/4/5]"
Microsoft ASP.NET Core 8.0.14 - Shared Framework (x86):".NET [2025/4/30]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
SP1:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "12th Gen Intel(R) Core(TM) i5-12400F"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 151 Stepping 2"
- "Chipset Name":"12th Gen Intel(R) Core(TM) i5-12400F"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=12th+Gen++Core+i5+12400F"
CPU Speed:"2.50 GHz"
Current Voltage:"1.6 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 上午"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Version:"10.0.26100.4768"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"6 x 288 KB"
Level 2 Cache:"6 x 7680 KB"
Level 3 Cache:"18 MB"
Load:"23%"
Manufacturer:"GenuineIntel"
Model:"151"
Name:"12th Gen Intel(R) Core(TM) i5-12400F"
Number of Cores:"6"
Number of Cores Enabled:"6"
Number of Logical Processors:"12"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF00090672"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"2"
- "Storage"
- "WD Blue SN580 1TB"
Capablities:"Random Access, Supports Writing"
Caption:"WD Blue SN580 1TB"
Cylinder - Total:"121601"
Description:"磁盘驱动器"
Error Code:"Device is working properly"
Firmware Revision:"281040WD"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(标准磁盘驱动器)"
Model:"WD Blue SN580 1TB"
Partitions:"5"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_WD_BLUE_SN580_1T\5&10333A3E&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Sectors - Per Track:"63"
Sectors - Total:"1953520065"
Serial Number:"E823_8FA6_BF53_0001_001B_448B_4DBD_41D0."
Size – Available:"165.46 GB"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"31008255"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"本地固定磁盘"
File System:"NTFS"
Serial Number:"7A07D3F8"
Size – Available:"119.79 GB"
Volume Dirty:"No"
- "D:"
Caption:"D:"
File System:"NTFS"
Serial Number:"CEC65022"
Size – Available:"45.67 GB"
Volume Dirty:"No"
...#SSU#...
Hi supi,
Thank you for the update. To troubleshoot this, please follow and answer the questions below:
- Could you share your complete game settings as they were originally configured?
- Try lowering your graphics settings temporarily to see if that helps.
- Does this problem occur in all camera views or only this specific one?
- Have you tested whether the issue persists in windowed mode?
- Are there any overlays running (Steam, Discord, etc.)? If yes, please try disabling them.
Archie D.
------ According to my test, it seems that the problem mainly occurs in the dx12 mode. Switching to dx11 eliminates this issue. As long as you switch to the dx12 mode, any settings can reproduce this error.
------ No
------ Only this specific one,The error occurs only when switching to the cockpit view; it does not happen in other views.
------ Yes, but the problem still exists.
------ No
Hi supi,
Thank you for the feedback. I will investigate this and will get back to you once a resolution is available. Thank you for your patience and understanding.
Archie D.
Hi @supi,
Thank you for reporting the issue you're experiencing with your B580 graphics card while playing War Thunder.
I take this matter seriously and want to ensure I will provide you with the most accurate and effective solution. To thoroughly investigate this issue and identify the root cause, I will need additional time to conduct comprehensive testing and analysis.
I'm currently working diligently to replicate the issue and explore all possible solutions. This detailed investigation will help us provide you with the best possible resolution.
I will keep you updated on our progress and provide you with a comprehensive update as soon as our investigation is complete. I appreciate your patience and understanding as I work to resolve this matter.
If you have any questions or concerns in the meantime, please don't hesitate to reach out.
Ernesto C.
Hi @supi,
I sincerely apologize for the delay in providing the promised update regarding the issue with War Thunder. I understand the importance of timely communication and regret any inconvenience this delay may have caused.
I am currently conducting a more thorough investigation to ensure I provide you with accurate and comprehensive information. This additional analysis is taking longer than initially anticipated, but it is necessary to address all aspects of the situation properly.
I am committed to delivering a complete update as soon as my investigation is concluded
Ernesto C.
