Intel® ARC™ Graphics
3278 Discussions
如何让A770 16G保持3GHZ.如何设计架构。
lvyelianshu
我玩AI的时候超频到3gHZ.稳定运行.方法是官方软件,电压和自适应全拉满.能超到3Ghz.但是有个BUG只能在20%功率才能达到.我想官方是否能优化下工艺或者软件.在低功耗是睿频到3Ghz.或者让计算单元与不重要的架构均匀分布.增加散热.这只是一个想法也不知道是否可行.
RandyT_Intel
Hi @lvyelianshu,
请注意,我只能用英语为您提供支持。我已经使用网络翻译工具来翻译此响应,因此可能存在一些不准确的翻译
Thank you for posting here in our community. I’ll coordinate this internally if your request keeping the Intel Arc A770 16G GPU at a stable 3GHz turbo frequency is feasible through official software or architectural adjustments
To help us better understand and investigate:
  • Screenshots of:
    • Your current configuration in the official software.
    • The settings used to achieve 3GHz (voltage, adaptive mode, etc.).
    • Any performance monitoring tools showing the 20% power limitation.
  • Clarification:
    • Is your A770 16G an Intel-branded card, or from a third-party manufacturer?
    • Are you using Intel Graphics Software or another tool for overclocking and monitoring?
Randy T.
RandyT_Intel
Hi @lvyelianshu,
Randy T.
RandyT_Intel
Hi @lvyelianshu,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
