Intel® ARC™ Graphics
告知
3413 ディスカッション
165hz option no longer available in advance display setting
Abhimata01
ビギナー
1,445件の閲覧回数
I have a 165hz monitor (Fantech Chimera GM271SF) as an extended display from my MSI GF63 Thin 11SC. A few months ago it was running on 165hz smoothly. But, since an intel driver update (I forgot which one), the option to run the monitor on 165hz is no longer available. Currently it's limited on 120hz. I didn't change the cable (HDMI 2.1) so I don't think it's a hardware problem. I have tried to install the recommended driver from the MSI website and also updated all of my drivers (GPU, CPU, and even BIOS) to the current version. But sadly it still doesn't fix the problem.
Any help would be much appreciated. Thanks.
0 件の賞賛
7 返答(返信)
JedG_Intel
モデレーター
1,364件の閲覧回数
Hello Abhimata01,
Thank you for posting at Intel Community Forum.
I understand that you are seeking assistance with regards to the resolution of your monitor. To help you with this, please try the recommendations on this link.
Please let me know if the recommendations helped or changed anything. In case the same issue occurs, please share the information below for me to investigate further.
1. Have you tried using other display cables?
2. Have you tried using OEM drivers?
3. Have you tried rolling back the driver?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Have a good one!
Jed G.
Abhimata01
ビギナー
1,319件の閲覧回数
Thanks for the suggestions but unfortunately the display settings still doesn't show the 165hz. For instance, 1) I bought a brand new 2.1 HDMI cable, 2) I've installed the recommended intel driver on the MSI website based on my laptop's model, 3) I've tried installing several driver that was available on the Intel website.
Based on a forum, I found that this problem is driver based. It's exactly the problem I'm having right now.
https://community.intel.com/t5/Intel-ARC-Graphics/144Hz-Monitor-stuck-at-120Hz-that-was-previously-working-at/m-p/1633266/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufE0xSEVaNjYxMThLQkI2fDE2MzMyNjZ8U1VCU0NSSVBUSU9OU3xoSw#M16744
JedG_Intel
モデレーター
1,266件の閲覧回数
Hi Abhimata01,
Thank you for sharing more information.
It seems that the link with the recommendations was not attached. Please see this link for the troubleshooting recommendations - Unable to Select the Native Resolution
Please let me know if it improves or changes anything.
Have a good one!
Jed G.
Abhimata01
ビギナー
1,245件の閲覧回数
Still doesn't fix the problem. Did the SSU report didn't give any useful information? And I don't understand which link is not attached, I'm pretty sure the SSU file is attached to my reply. Really hope you could help me to find a solution. Thanks.
JedG_Intel
モデレーター
1,132件の閲覧回数
Hello Abhimata01,
I apologize for the confusion. The link with the recommendation was not attached to my first response hence why I attached it on my second response. For clarification, this is what I'm talking about -
Additionally, are you using discrete graphics for the external display? To further isolate the issue, could you please try using iGPU and check if the same issue will occur?
I hope to hear from you soon!
Jed G.
JedG_Intel
モデレーター
1,070件の閲覧回数
Hello Abhimata01,
Jed G.
JedG_Intel
モデレーター
1,025件の閲覧回数
Hello Abhimata01,
Jed G.
返信
