Intel® ARC™ Graphics
3420 Discussions
A770 16G
wdder
你好!10.0.26100.3323为什么C4D提示还是老版本的GPU,软件推荐27.20这个版本的当前的图形驱动程序已过时。 我们建议更新为最新的#驱动程序,以提高性能和稳定性。
wdder
配置如下Dxdiag.txt中,BIOS中Resizable BAR 已开启 BIOS版本:JYZ7PA34
依然是:你好!10.0.26100.3323为什么C4D提示还是老版本的GPU,软件推荐27.20这个版本的当前的图形驱动程序已过时。 我们建议更新为最新的#驱动程序,以提高性能和稳定性。
DhannielM_Intel
Hello wdder,
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译
Thank you for posting in the community. The description and subject are a bit unclear, so I would like to ask for some clarification. Could you please answer the following questions:
  1. Since I can only provide support in English, could you paste the error code in the thread so I can translate it, or could you change the language to English? I apologize for any inconvenience this may cause.
  2. Is this issue preventing you from using the application?
Dhanniel M.
DhannielM_Intel
Hello wdder,
I'm just checking to see if you've had a chance to review my previous response regarding the additional questions. At your earliest convenience, please let me know so we can proceed with the investigation.
Dhanniel M.
DhannielM_Intel
Hello wdder,
Since I haven't received a response from you, I will proceed to close this inquiry. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored. Thank you for your understanding.
Dhanniel M.
