Intel® ARC™ Graphics
3469 Discussions
ARC B580 - Menus are sluggish in the godot editor.
TeHbBoMpake
The problem has already been described in isue in the redot repository here: ARC B580 - Menus are sluggish in the redot editor. · Issue #921 · Redot-Engine/redot-engine
This issue is relevant for godot 4.4
ArielP_Intel
Hello TeHbBoMpake,
Thank you for posting in Intel Communities! I understand that you are experiencing an issue with Redot and its compatibility with the Arc B580.
To assist you further, could you kindly provide the following details:
  1. What is the exact driver version you have installed?
  2. Have you tried using Display Driver Uninstaller (DDU) to completely remove and then reinstall your graphics drivers?
  3. When did the issue first occur?
  4. Is the problem consistent or intermittent?
Your clarification is greatly appreciated. Looking forward to hearing from you soon!
Ariel P.
ArielP_Intel
Hello TeHbBoMpake,
I would like to follow up and ask if you've had the chance to review my previous response, where I asked a series of questions in order to better assist in finding a resolution for your issue.
Looking forward to your response!
Ariel P.
ArielP_Intel
Hello TeHbBoMpake,
Ariel P.
TeoJae
I am having similar issues as well as tool-tips disappearing when I hover my mouse over menu items.
1. I am on driver version 32.0.101.6737
2. I did use DDU
3. It occurred from the first day I got my B580.
4. The problem is constant.
I hope this helps find a solution, if I don't get a reply I will submit my own ticket. TY c:
Ma11owMarsh
https://github.com/godotengine/godot/issues/103087
This GitHub issue describes the problem more precisely.
