- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi! I have posted here previously, but life caught up and unfortunately the thread was closed. Here is an updated ticket, with more information.
Hi! I am running a Intel ARC A380 and a Nvidia RTX 3070. I have the RTX 3070 in the first x16 slot on my motherboard, and the ARC gpu in the one below it. I am attempting to assign OBS to run on the ARC gpu, but in windows power management settings, ARC does not appear as a low power option to assign the program to. See picture attached. The arc gpu appeared properly when the nvidia gpu was disabled, but only then. I know ARC is supported, because when the NVIDIA gpu was disabled, it booted and defaulted to that GPU without issue. I am on the current windows 10 installation build 19044.2728. Please let me know if you have more questions/information. Just looking to use this gpu as a video encode and video processing gpu when doing those workloads. Thanks!
Attached is the intel support scan logs (with and without the RTX 3070 disabled) and a screenshot of the ARC GPU appearing ONLY when the 3070 is disabled in device manager.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello riskofrainenjoyer,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Arc™ A380 Graphics
1. Do you see both cards in the device manager?
2. Have you checked with Asus to confirm if the motherboard supports hybrid graphics?
3. Did you run all Windows updates?
Deivid A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Yes, both devices are appearing in device manager. The motherboard does have the bandwith to support dual gpu, and when running a handbrake test, the AV1 encoding option appeared, and I used it. It used the arc gpu properly with the Nvidia gpu enabled as well. Windows is fully up to date.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Before we continue further I would like to confirm if your issue is only that both cards do not appear in the Windows power management settings. Is the Arc graphics card having any other issues?
Can you please provide the Intel® Graphics Drivers?:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
Deivid A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
No, the issue is the ARC GPU does not appear in windows. The nvidia gpu is fine. The issue is the arc gpu does not appear as an option with both enabled. I am currently using 31.0.101.4255 version. I just updated, didn't fix it. The last couple drivers I tried to roll back to had no change as well.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you for the information provided
Deivid A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Before we continue further with the investigation, can you confirm the behavior when you tried just the Intel® Arc™ A380 Graphics
one, then when connecting the Nvidia without removing the Intel® Arc™ A380 Graphics.
I will appreciate it if you can provide more details.
Deivid A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I'm not exactly sure what you are asking. When the Nvidia GPU is disabled as a device, so that only the arc gpu is utilized, OBS has no issue grabbing those AV1 settings, and windows has no issue seeing the arc GPU as a device to pick between power saving and performance modes. Both options are labeled as the Arc card of course, but it appears. After reenabling (connecting) the Nvidia gpu, the Arc gpu disappears from those power management app settings, to be replaced by the Nvidia GPU, for both power saving and performance options. If that's not quite what you're looking for, feel free to provide specific instructions or details.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for the information provided. I will continue with the investigation and get back to you as soon as possible.
Thanks for your comprehension.
Deivid A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Before we continue further, I would like you to test the Intel® Arc™ A380 Graphics in the first x16 slot on the motherboard and the RTX 3070 in the second slot.
Please let me know if the issue persists.
Deivid A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Ok. I will get back to you later tonight or tomorrow, and try that.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Alright, after switching the GPUs around, OBS worked fine with the ARC gpu, and I was prompted to use AV1 encoding etc. The windows graphics manager gave me only the ARC gpu, and everything worked smoothly. Problem still stands that id like to play and render games on the nvidia card, while encoding with the arc.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for the confirmation. Just to double-check, now the Windows power management settings only see the Arc GPU and not the Nvidia GPU when both are connected, is that correct?
Have you checked with the motherboard manufacturer to confirm that this behavior is normal? Or/and, did you check with Microsoft to confirm if the Windows power management settings only use the card installed in teh first slot?
I will be waiting for your confirmation.
Deivid A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I'm not sure on either. When I asked for support in the OBS community, they gave me examples of two distinctly different cards appearing in those power management settings. I will look into the windows side of things.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
To answer your question though, yes. The arc GPU appeared as both options even as the Nvidia card was connected in the second slot.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Not sure what changed in the last few days, but it has fixed itself now. Just checked OBS and I have all the settings I am supposed to have. Not sure what updated, but thanks for all the support!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Just wanted to check, does it show two separate graphics cards in your Windows Graphics Settings now or was it just OBS that fixed itself?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for your confirmation. I am glad to know that the issue was fixed and know you can see all the options wanted in the app.
I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
